Pouring A Sauna Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-13-2012, 01:29 AM   #1
Rewards Points: 87
pouring a sauna foundation
Hello,
This is a layout of the setup I have for my sauna:
From what I have calculated I will need about 2.2 cubic yards of cement.
That is based on :
8' x 1.5' x 1.5' = 18.00 cubic ft.
9' x 1.5' x 1.5' = 20.25 cubic ft.
The space for this sauna is pretty centrally located on my property and I will probably be carrying in the cement for this and mixing it in a mixer with help from a friend.
This foundation will be supporting a cinderblock retaining wall that will be about 8' - 10' feet in the back and taper down as needed on the two sides.
Can I use Quickcrete for this application?
Am I better off buying bags of Portland cement / sand / aggregate and making my own mix?
How do I accurately calculate the amount of Quickcrete and or Cement/Sand/Aggregate mix I will need? (If I have done it wrong)
Any other suggestions or things I need to take into account would be appreciated! Thanks!
hellonoko is offline   Reply With Quote
Old 02-13-2012, 06:01 AM   #2
DIY staff
Rewards Points: 7,174
Go to the how to section----there is a calculator there for bags of concrete---
I'm not a mason or engineer --so that's all I've got.
Old 02-13-2012, 07:12 AM   #3
Civil Engineer
Rewards Points: 4,860
I don't see the "cinderblock" retaining wall you mentioned. If it is really retaining 8-10 feet of soil, it needs to be carefully engineered, and certainly cannot be made from cinderblock, but most likely would have to be either segmental block retaining wall with reinforcing or cast in place reinforced concrete. Or perhaps I don't understand what you are saying at all.
Daniel Holzman is online now   Reply With Quote
Tags
concrete , foudation , sauna
cost of digging and pouring the foundation modkfx450 Building & Construction 10 03-10-2011 08:20 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 02:51 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
