Pouring Garage Footers. - Concrete, Stone & Masonry - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-13-2013, 04:31 PM   #31
I can build structures all day long to a certain size. But have never built anything they required being bolted to the ground. Exc.
I don't have $10-20 grand for someone to build a garage. Once I get the foundation done. I won't ask another question.
I'll be happy if it last 5 years for me. If I fail. At least I can say I tried and learn from my mistakes.
Itscody is offline   Reply With Quote
Old 05-13-2013, 04:52 PM   #32
GBrackins's Avatar
Rewards Points: 2,108
I haven't read every post so I may have missed this ...... if you build your wooden walls at grade level you will probably have issues with rot. we typically have them at least 8" above the ground
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-13-2013, 04:55 PM   #33
I am planning on being 4-6" above ground and slooping the yard for water to run away from slab.
Old 05-13-2013, 05:45 PM   #34
Rewards Points: 3,628
There's a code for spacing of the j bolts,you'll have to ask your local building department
6 inches above grade is better.
Canarywood1 is online now   Reply With Quote
Old 05-13-2013, 05:46 PM   #35
I live way out of city limits. So I'll have to see if I can track somebody down to answer that then.
Old 05-13-2013, 08:16 PM   #36
If i were to guess i'd say 5/6 feet apart you'd be okay,just don't position them on the ends,at least 3/4 feet in
Old 05-13-2013, 08:24 PM   #37
Okay thanks for all the answers. I believe I should be able to knock this out fairly easy.
Although I'm debating if I should add a little crub or something. To give it a little base type deal.
Old 05-13-2013, 08:45 PM   #38
Rewards Points: 626
What All is needed to pour garage footer.
For a 30x30 garage.
Just a question not directed at just you but most people from the east coast and south east. Why do you call footings footers? it just sounds weird.
Nailbags is offline   Reply With Quote
Old 05-13-2013, 08:47 PM   #39
I'm not from this area. So I couldn't answer that lol. I just say it how the concrete guys say it here.
Old 05-13-2013, 09:00 PM   #40
Rewards Points: 236
indeed. my dad was in concrete. when i was a kid, i carried TONS of forms, and i pounded LOTS of stakes. and i helped pour LOTS on concrete.
"footings" is what we called em.
Fix'n it is offline   Reply With Quote
Old 05-13-2013, 09:06 PM   #41
With that being said.
I dug about 6 ft deep in the area I'm building.
Pouring concrete in about a week. What should I use / do to prep ground before they come. Since its not 100% settled in. The guy mentioned something about 6610
Old 05-13-2013, 09:38 PM   #42
Concrete & Masonry
Rewards Points: 576
That's a reference to wire mesh re-enforcement, 6 x 6 x 10 gauge...........
jomama45 is online now   Reply With Quote
Old 05-13-2013, 09:48 PM   #43
Gotcha. any suggestions on the soil where it's been freshly dug in to or will the wire mesh be good.
Old 05-14-2013, 10:01 AM   #44
Rewards Points: 626
Well lets see in the footings place a double run of #4 rebar in on the slab part crushed rock and over that a 6Mil min visqueen moisture barrier then your 6610 on that. your good to go.
Old 05-14-2013, 10:05 AM   #45
All this underneath slab area and ill be good to go.
Thanks.
What size boards should be used to box area in.
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Garage and breezeway footers Npc5629 Building & Construction 2 07-27-2011 11:32 AM
