Pouring Garage Footers. - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-12-2013, 09:24 PM   #16
Concrete & Masonry
Rewards Points: 526
Originally Posted by framer52 View Post
we build them all the time, yet to have one fail yet.
Here as well, and I'm actually pouring a little 22' x 22' in the morning. I've been involved in pouring grade beam slabs well over 100' long with no problems. Regardless of where you are located, there should be some specifications for the height and width of the grade beam/thickened edge, as well as a minimum amount of re-enforcement...........
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 05-13-2013, 04:42 AM   #17
Rewards Points: 4,534
ky is subject to frost so common sense will dictate the footer depth,,, it it were ours, we'd pour footer w/steel as recommended & leave a final height 6" above grade,,, start framing to that,,, you can always come back later & place the floor which floats on the slab,,, in the meantime you can park on the base of crushed stone or compacted ( graded aggregate base/crusher run ),,, put in a good joint pattern to prevent random cracking,,, 3 longitudinal & 3 transverse cuts should do it easily )will result in less than 8' x 8' slabs
here's an even better suggestion - find a retired conc guy & be his friend,,, then hire him to help - he sits & directs, you do the work,,, pay him enough as you're buying his knowledge & experience,,, personally, when down at the shore, i work for greens fees :-)
Old 05-13-2013, 08:35 AM   #18
How deep would you go down in the ground, 6" up top. 8" in ground. To have a footer over 1 foot in total height.
Itscody is offline   Reply With Quote
Old 05-13-2013, 08:49 AM   #19
1' would be fine here in atl but, in ky, i have no idea,,, but, as much as we all like to see ourselves in print, i'm sure someone will respond
Old 05-13-2013, 08:51 AM   #20
1 ft in ground or total height in atl
Old 05-13-2013, 08:52 AM   #21
1' in ground
Old 05-13-2013, 08:56 AM   #22
1' in ground
Gotcha. 18" total height.
Old 05-13-2013, 11:56 AM   #23
Rewards Points: 3,418
For your location,jomama's way is all that's needed,and footing along with slab done in one pour,no need to do any digging.
Canarywood1 is online now   Reply With Quote
Old 05-13-2013, 11:58 AM   #24
And then just build on top of the footing, correct?
Old 05-13-2013, 04:42 PM   #25
You'll actually be building on top of the slab,footing is under the slab.
Old 05-13-2013, 04:58 PM   #26
So no digging. Slab poured. Garage built on slab.
Should I use. J bolts - put in to cemet and bolt walls to them or drill holes in slab use epoxy and put bolts in that way.
Old 05-13-2013, 05:06 PM   #27
J bolts added when slab is poured.
Old 05-13-2013, 05:12 PM   #28
Got quoted for $1200 to pour 30x30 slab 4 inches deep. 5 inches. In corner with lift.
What's a good way to box in the area and prep for them to come pour.
Old 05-13-2013, 05:12 PM   #29
And how many j bolts should be used or Howard every so many feet.
Old 05-13-2013, 05:21 PM   #30
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
Sorry...but I see this shaping up for failure....not trying to rag on you....but if your asking these kinds of questions, then your way in over your head.
Now it's only fair to point out I was in the same boat about 5 years ago when I did my garage....I paid someone else to do it....and learned a lot along the way.
Like Joe said...you only get one shot at it...fixing it afterwards is not going to be cheap.
ddawg16 is online now   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 08:54 AM
Garage and breezeway footers Npc5629 Building & Construction 2 07-27-2011 12:32 PM
