Pouring Garage Footers. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-12-2013, 10:07 AM   #1
Pouring garage footers.
What All is needed to pour garage footer.
For a 30x30 garage.
Itscody is offline   Reply With Quote
Old 05-12-2013, 10:35 AM   #2
Rewards Points: 216
we need more info than that. but, round here, the footing and slab are 1 piece.
Fix'n it is offline   Reply With Quote
Old 05-12-2013, 10:38 AM   #3
Okay. I'm doing the slab at a later time.
I'd like to get the foundation built so I can go ahead and put up the walls and roof.
Old 05-12-2013, 10:38 AM   #4
Rewards Points: 216
oh. 30x30 is a nice size.
Old 05-12-2013, 10:41 AM   #5
Would like 40x40. But decided to go with 36x36. Then realized finically better if I went with 30x30.
So 30x30 should so what I need lol.
Old 05-12-2013, 10:43 AM   #6
Rewards Points: 216
yeah. i am sure there are ways to do that in an ok way. but my MIL's garage was done that way. it is a freaking mess. the foundation settled 3 different ways. and the slab settled 3 different other way.
Old 05-12-2013, 10:43 AM   #7
Rewards Points: 13,270
To even make some guesses your going to have to go back and add your location to your profile. Just go to quick links to edit.
Need to call your local utilty locating service before any digging.
This is going to need a permit.
This is one job that I would hire out. Done wrong and there's no going back, the rest of the building will suffer.
Old 05-12-2013, 11:00 AM   #8
I'm in Kentucky.
I have had all lines marked already. I do not need a permit. Due to being out of city limits.
So it's a green light to go.
Old 05-12-2013, 11:24 AM   #9
GBrackins's Avatar
Rewards Points: 2,108
footing size is based upon the load it must support and the soil bearing capacity. is this a one story garage or will there be a second floor?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-12-2013, 11:32 AM   #10
It will be a one story. Detached.
Old 05-12-2013, 11:54 AM   #11
Rewards Points: 528
I would pour a floating slab for the foundation for this.
You don't need footers if you build it this way.
framer52 is offline   Reply With Quote
Old 05-12-2013, 12:09 PM   #12
So 30x30 garage.
Detached with one story.
On a floating slab.
Sounds a lot easier and sounds like it will save money.
Old 05-12-2013, 03:28 PM   #13
Where not even allowed to build anything but a stem wall foundation for a garage around here.
http://www.bing.com/images/search?q=...electedIndex=1
It needs two rows of rebar, has to be below the frost line, 2' wide and 8" thick.
It needs to be at least 6" higher then the finished grade.
Old 05-12-2013, 03:35 PM   #14
Rewards Points: 528
we build them all the time, yet to have one fail yet.
Old 05-12-2013, 03:46 PM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
In the long run, pouring the slab and footing at the same time is easier and cheaper
Click on the garage link in my signature for an example.
One thing frequently over looked when you do the slab later is how muddy it is. The space for you slab end up being a mud hole.
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 08:54 AM
Garage and breezeway footers Npc5629 Building & Construction 2 07-27-2011 12:32 PM
