-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Pouring garage footers. (http://www.diychatroom.com/f105/pouring-garage-footers-179364/)
Itscody 05-12-2013 09:07 AM
What All is needed to pour garage footer.
For a 30x30 garage.
Fix'n it 05-12-2013 09:35 AM
we need more info than that. but, round here, the footing and slab are 1 piece.
Itscody 05-12-2013 09:38 AM
Okay. I'm doing the slab at a later time.
I'd like to get the foundation built so I can go ahead and put up the walls and roof.
Fix'n it 05-12-2013 09:38 AM
oh. 30x30 is a nice size.
Itscody 05-12-2013 09:41 AM
Would like 40x40. But decided to go with 36x36. Then realized finically better if I went with 30x30.
So 30x30 should so what I need lol.
Fix'n it 05-12-2013 09:43 AM
yeah. i am sure there are ways to do that in an ok way. but my MIL's garage was done that way. it is a freaking mess. the foundation settled 3 different ways. and the slab settled 3 different other way.
joecaption 05-12-2013 09:43 AM
To even make some guesses your going to have to go back and add your location to your profile. Just go to quick links to edit.
Need to call your local utilty locating service before any digging.
This is going to need a permit.
This is one job that I would hire out. Done wrong and there's no going back, the rest of the building will suffer.
Itscody 05-12-2013 10:00 AM
I'm in Kentucky.
I have had all lines marked already. I do not need a permit. Due to being out of city limits.
So it's a green light to go.
GBrackins 05-12-2013 10:24 AM
footing size is based upon the load it must support and the soil bearing capacity. is this a one story garage or will there be a second floor?
Itscody 05-12-2013 10:32 AM
It will be a one story. Detached.
framer52 05-12-2013 10:54 AM
I would pour a floating slab for the foundation for this.
You don't need footers if you build it this way.
Itscody 05-12-2013 11:09 AM
So 30x30 garage.
Detached with one story.
On a floating slab.
Sounds a lot easier and sounds like it will save money.
joecaption 05-12-2013 02:28 PM
Where not even allowed to build anything but a stem wall foundation for a garage around here.
http://www.bing.com/images/search?q=...electedIndex=1
It needs two rows of rebar, has to be below the frost line, 2' wide and 8" thick.
It needs to be at least 6" higher then the finished grade.
framer52 05-12-2013 02:35 PM
we build them all the time, yet to have one fail yet.
ddawg16 05-12-2013 02:46 PM
In the long run, pouring the slab and footing at the same time is easier and cheaper
Click on the garage link in my signature for an example.
One thing frequently over looked when you do the slab later is how muddy it is. The space for you slab end up being a mud hole.
