Poured Concrete Porches - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-05-2014, 09:50 AM   #1
Poured concrete porches
I have recently built a "Reward Wall" ICF (insulated concrete form) home. My contractor opted to pour concrete porches using ICF forms. I do not know if the engineering was defective or the workmanship and materials were not acceptable. The end result is I have leaks through the walls of my home. The proches (6), 3 in the front and 3 in the back of the house are stamped. Is there a clear finish I can apply that will water proof the concrete? It appears the concrete is absorbing water and it is coming into the home. This is a stucco home exterior finish. The contractor has been working on this issue for over a year with unacceptable results.
Walter Bostic is offline   Reply With Quote
Old 01-05-2014, 10:02 AM   #2
Rewards Points: 13,300
Got some pictures?
Did they pore these slabs even with the door openings?
Old 01-05-2014, 09:44 PM   #3
Rewards Points: 940
The Rewards system has a ceiling system as well. Is this what the porch floors are made of?
I'm assuming that this has been leaking for some time and is not just a result of our recent cold snap and some condensation.
The floor needs to be pre-sloped and waterproofed. Then naturally the concrete on top gets sloped as well.
If you need to waterproof now, you will have to choose something.
There are probably many options in coatings. I would consider waterproofing the concrete with something like Hydro-ban, then tiling the surface.
I guess if the floor is not sloped, this will have to be addressed first.
cleveman is offline   Reply With Quote
Old 01-07-2014, 05:28 AM   #4
Rewards Points: 4,534
since we haven't heard further from walter, can we assume he's resolved the problem, has no camera, isn't interested is a solution, or died/been captured by somnali pirates ?
i don't know of a ' waterproofing ' solution that solve this problem but, it we knew more information, we might - too bad !
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Remove Poured Concrete Block doingitgirl Concrete, Stone & Masonry 4 08-04-2013 08:34 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Removing concrete poured over tile in basement nkjetman Building & Construction 6 01-31-2009 05:55 PM
Freshly poured concrete rocks showing through top of it why? yo24 Building & Construction 3 01-28-2009 06:25 PM
