-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Poured concrete porches (http://www.diychatroom.com/f105/poured-concrete-porches-193329/)
Walter Bostic 01-05-2014 08:50 AM
I have recently built a "Reward Wall" ICF (insulated concrete form) home. My contractor opted to pour concrete porches using ICF forms. I do not know if the engineering was defective or the workmanship and materials were not acceptable. The end result is I have leaks through the walls of my home. The proches (6), 3 in the front and 3 in the back of the house are stamped. Is there a clear finish I can apply that will water proof the concrete? It appears the concrete is absorbing water and it is coming into the home. This is a stucco home exterior finish. The contractor has been working on this issue for over a year with unacceptable results.
joecaption 01-05-2014 09:02 AM
Got some pictures?
Did they pore these slabs even with the door openings?
cleveman 01-05-2014 08:44 PM
The Rewards system has a ceiling system as well. Is this what the porch floors are made of?
I'm assuming that this has been leaking for some time and is not just a result of our recent cold snap and some condensation.
The floor needs to be pre-sloped and waterproofed. Then naturally the concrete on top gets sloped as well.
If you need to waterproof now, you will have to choose something.
There are probably many options in coatings. I would consider waterproofing the concrete with something like Hydro-ban, then tiling the surface.
I guess if the floor is not sloped, this will have to be addressed first.
stadry 01-07-2014 04:28 AM
since we haven't heard further from walter, can we assume he's resolved the problem, has no camera, isn't interested is a solution, or died/been captured by somnali pirates ?
i don't know of a ' waterproofing ' solution that solve this problem but, it we knew more information, we might - too bad !
