Please Advise On Leaking Basement Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-29-2013, 02:43 AM   #1
Please advise on leaking basement wall
Hello I noticed mold growing all over one side of my basement , then i lifted up one of the wood floor tiles and saw there was a lot of water. I thought it might be a plumbing issue so I cut open where the bathroom drain is in the wall to look and I see that when it rains water is just pouring through this wall.
I made a video which you can see clearly what is going on better then me explaining , if you could take a look that would be great
if you watch further you can see the stain? or crack? goes up as far as i can see
What would you recommend?
Thank you
carlx is offline   Reply With Quote
Old 04-29-2013, 05:31 AM   #2
Rewards Points: 4,578
there's tons of threads re wet bsmts w/solutions ranging from sub-floor perimeter drainage systems ( poss incl sump & pump ) to ext excavation ( poss incl sump & pump, too ),,, not difficult finding applicable solutions,,, looks as if your bsmt wall is concrete so the structural integrity is probably still sound.
ps - NONE of the solutions incl painting/applying a ' drylock ' type cememtitious mtl OR any other ' silver bullet ' onto the interior wall surfaces regrading the exterior & redirecting downspout discharge won't fix it, either, altho that's always recommended.
( your location is ALWAYS helpful for pertinent responses ! )
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 08:07 AM
Wall leaking at base tunaman Building & Construction 6 01-11-2011 12:29 AM
Basement wall leaking after 3 professional repairs unfortunateluck Building & Construction 20 12-21-2010 09:18 AM
Water leaking through basement wall dismas Building & Construction 19 10-26-2010 05:06 AM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
