Permits - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-09-2013, 10:33 AM   #1
Permits
Just a quick question. This summer I want to dig around my house and check the foundation/footers and re seal everything. I was curious if It is necessary to obtain a permit to do this work. I know I obviously need to call and find out where all the utility lines are obviously.
Kurtiswm is offline   Reply With Quote
Old 06-09-2013, 12:21 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
Call your local jurisdiction....they will be glad to tell you if you need permits. I suspect that you will only need one if you plan to make certain repairs that would require an inspection.....
ddawg16 is online now   Reply With Quote
Old 06-09-2013, 02:27 PM   #3
Rewards Points: 3,610
What exactly do you intend to reseal???
Canarywood1 is offline   Reply With Quote
Old 06-09-2013, 02:33 PM   #4
I want to repoint any mortar in the cinder blocks that may need fixing, tar and mesh and that textured plastic stuff.
Old 06-09-2013, 03:05 PM   #5
Old School
Willie T's Avatar
I can only speak for here, but that particular work is not inspected in my area.
Willie T
Plumber didn't pull permits and work is not to code...what now? TwistedCubic General DIY Discussions 19 05-25-2013 10:24 PM
Open permits? WillK Building & Construction 1 09-10-2012 02:34 PM
Estimate for plans + permits + sub-foundation stuff + foundation? shinyhalo Building & Construction 5 10-07-2011 08:29 PM
Help ... permits joyjoy Remodeling 2 11-26-2010 06:30 AM
