Are Pennsylvania Bluestone Pavers Suitable For A Residential Driveway? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-30-2012, 11:52 AM   #1
Rewards Points: 508
Are Pennsylvania Bluestone Pavers Suitable for a Residential Driveway?
I'm wondering if these 2" tumbled pavers would be suitable for a residential driveway?:
Are Pennsylvania Bluestone Pavers Suitable for a Residential Driveway?-kgrhqv-nue-w5o-kywbps-b3f-tq-60_57.jpg
benjamincall is offline   Reply With Quote
Old 05-30-2012, 08:32 PM   #2
Remodeling Contractor
no. these will de-laminate under the weight of a vehicle in short time.
Old 05-30-2012, 08:55 PM   #3
Rewards Points: 508
Good for a patio, though?
Old 05-31-2012, 05:22 AM   #4
yes, but don't pack your monster truck there.
Old 03-16-2015, 01:17 PM   #5
Rewards Points: 508
Bob,
Recently I've seen pictures of people using bluestone in driveway applications:
Before I get the final CO from the town, I need to pave the first 25 feet of the 600 foot driveway with a hard surface (I have asphalt millings at this point).
This 25-foot apron would not be someplace where people park with any regularity.
I want to dry lay the stone (variable thickness from 1-3", not the stuff I proposed using when I started this thread) over the asphalt millings. Would delamination be that unattractive? I imagine it would only happen to those stones that we drive over, so I could lift them out and replace them every so often, right?
Old 03-16-2015, 05:34 PM   #6
Rewards Points: 4,534
'bout all they're good for is a patio imo, they'd crack before delaminating
Old 03-16-2015, 05:44 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,.... Have you ever tried diggin' in millin's that have been repeatedly driven over,..??
It's gonna be 'bout as hard as concrete,....
Gettin' a reasonably flat drivin' surface will be pretty tough to,...
Those pictures are Purtty,... I'd like to see those places after 10 years, 'n 100s of traffic crossin's,.....
Old 03-16-2015, 08:28 PM   #8
Rewards Points: 508
Do you think a smaller size would make a difference? Would the cracks look that terrible?
The millings have been down since late November. I was thinking of taking it down about three inches. A mini ex would be up to the task.
If you fellows are pretty sure it will look like garbage, I won't waste my time.
I wouldn't mind the chore of replacing some here and there since they cost me only about $85 a pallet.
Old 03-17-2015, 03:14 PM   #9
Bondo's Avatar
Rewards Points: 650
Ayuh,.... I work with millin's, Alot,...
I'm in the blacktop biz, May to November, 23rd season about to start,.....
If you regrade the millin's to a nicely pitched, 'n smoothly graded finish,...
Then bring in a 3 ton/ 5 ton double drum blacktop roller, 'n Pound the 'ell out of it,....
Yer Inspector, just might buy it as a Hard Surface apron,...
If it's Pounded in, durin' a Hot, Sunny day, he'd think he was lookin' at binder blacktop,....
'cept for the gray color, 'n the occasional paint line chip showin',....
'ell,... carefully sealcoat it black, after it's beat in, 'n he'll think he's seein' brand new blacktop,.....
The Following 2 Users Say Thank You to Bondo For This Useful Post:
benjamincall (03-24-2015), landfillwizard (03-17-2015)
Old 03-17-2015, 04:25 PM   #10
landfillwizard's Avatar
Rewards Points: 502
I agree with Bondo on the millings. If you level the milling and on a hot day spray with a little kerosene on top then hit with a vibratory smooth drum roller, it will look almost like hot asphalt pavement.
landfillwizard is offline   Reply With Quote
Old 03-17-2015, 04:45 PM   #11
ZTMAN's Avatar
Rewards Points: 244
Just a question to verify. Is that real blue stone on those pallets or the cultured stuff made to look like blue stone
ZTMAN is offline   Reply With Quote
Old 03-24-2015, 12:02 PM   #12
Rewards Points: 508
Excellent notion. The county doesn't require brand new blacktop, and I think what you're describing would qualify as a hard surface.
Unfortunately, I was in the hospital for a week with my daughter (hospital called CPS, and we had a big legal showdown). While I was tied up, my mom paid a deposit to an asphalt company for new asphalt. The apron is going to cost around $3000.
I'm going to use the technique you described for the rest of the driveway. What equipment would you recommend to grade the drive? Three-point blade? Front-end loader? My dad uses a motor grader he owns for his gravel roads, but I'm not sure where to rent one in Jersey.
Yes, that is real Pennsylvania bluestone.
Old 03-24-2015, 02:45 PM   #13
Bondo's Avatar
Rewards Points: 650
Ayuh,.... We mash up the millin's, 'n run 'em through the Paver,....
If ya can find a "Cat Skinner", a dozer can easily do the job, he's just gotta back-drag to erase the dozer tracks,...
Yer Dad's grader would No doubt be a Great tool for the job,....
A wheelbarrow, shovel, 'n rake Can do the job, but Man, it's a ton of work,....
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
Pavers over old concrete driveway GEORGEJ Concrete, Stone & Masonry 4 06-05-2012 02:55 PM
sloped residential driveway help Newontheblock Building & Construction 5 12-31-2011 07:52 AM
Brick pavers on driveway ???? sflamedic General DIY Discussions 2 04-21-2008 12:12 PM
