Pavers Over Concrete Sidewalk - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-18-2013, 08:02 PM   #1
pavers over concrete sidewalk
I plan on mortaring pavers over my existing sidewalk. I recently pulled up all the sections and re leveled as it had been channeling water towards the house. Since I am in a northern climate, would it help if I fasten the sidewalk sections together with some kind of metal strapping before laying mortar and pavers? I would think that if anything moved it would at least move together.
sleseman is offline   Reply With Quote
Old 07-18-2013, 09:41 PM   #2
Rewards Points: 13,300
If it was mine I would install metal edging, and use sand as a base, lay the pavers add more sand to fill the gaps.
Reason being as that concrete settles, flexes and cracks the pavers will float instead of also cracking and coming loose.
Old 07-18-2013, 09:44 PM   #3
Rewards Points: 222
remove the sidewalk and start fresh.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
joecaption (07-18-2013)
Old 07-19-2013, 02:25 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
The pavers and the original sidewalk will expand and contract at a different rate, meaning that the mortar joint will break and the pavers will be loose. Any hairline cracks in the mortar will take on water that will freeze and pop the pavers off. If the pavers overhang the edge of the slab, the ground will freeze and lift them. I have seen all three of these happen on the exact same type of sidewalk you are proposing. You are better off letting them set in a bed of sand and installing an edge to keep them corralled into place.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Old 07-23-2013, 11:19 PM   #5
Rewards Points: 4,534
mason sand for bedding & polymeric sand to sweep into the joints
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Sidewalk Concrete Forms next to house jimsi Concrete, Stone & Masonry 2 05-25-2012 11:30 AM
concrete sidewalk cushone24 Building & Construction 1 10-03-2010 02:32 PM
sidewalk using gravel and pavers misternubbs Landscaping & Lawn Care 2 10-06-2009 06:01 PM
