Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-22-2012, 07:44 AM   #1
Parge coat
I am adding a small addition to the house and am running out of weather. I have the addition sided, two layers of Tyvek, and self-furring lathing in place to support thin brick (that will match the house). I am considering hiring a mason to install the parge coat. The job is approximately 150 square feet (most of the addition is windows). How long should it take one to install the parge coat and what would you believe would be a fair rate to both the mason and me?
I can easily supply all materials and have water available via a hose a few feet away.
riddlers is offline   Reply With Quote
Base color coat sticking better then primer? konsole Painting 8 08-22-2012 07:12 AM
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 02:55 PM
Proper Way to Parge Coat? HandyDave Concrete, Stone & Masonry 3 04-24-2012 01:48 PM
Stucco: Is it better to use 1 coat of of finish coat throughout or 3 coat system? psubaron Building & Construction 5 10-06-2011 08:48 AM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
