#1 |
paint block basement walls
My 1954 house has block foundation. The whole basement feels dingy and I finally decided to paint it
. The walls get wet from heavy rains and finishing the basement does not seem to be possible. What is the best thing I can do to make my basement look better? I don't know what kind of paint I can use. Should I dry the walls completely first? Any advice is very much appreciated ![]() |
#2 |
Paint is never ever going to work on walls that get wet.
You need to be addressing the outside of that area not inside. Sealing the block with foundation seal on the outside below grade. Working gutters, Grade that runs away from the foundation. French drains. No mulch pilled up againt the foundation. No flower beds forming ponds. |
#3 |
I am trying to do all of it and hope that the water will stop entering the basement... I am not trying to seal the walls with paint but I just want the basement to look brighter
Is it possible, or the paint is not going to stick?
#4 |
Not going to work and would be peeling off within a year then your stuck with trying to get it off.
And no Dri-Loc is not the anserwer. |
#5 |
I've seen floors painted grey. May be I can do at least that?
#6 |
Coconut Pete's paella!
paint block basement walls |
#7 |
I had a little moisture issue in my basement, and I used Drylok. People either love or hate Dry-Lok... it does not fully solve the problem, but it all depends on you and what you want. Drylok is a good band-aid for me for now, as I do not plan to be in the house beyond a decade. It did the trick as well - dry as can be. Other than that, as others have said - get that drainage - grading and gutters
| Display Modes | |
| FINISHING BASEMENT WALLS - Cinder Block Walls | tmacwith | Building & Construction | 4 | 12-06-2012 09:26 AM |
| recurrent peeling paint on interior walls | Krista2 | Painting | 14 | 09-10-2011 04:17 PM |
| Waterproof paint on block walls | koolie | Painting | 9 | 03-23-2011 07:50 PM |
| basement block walls | twrozz | Building & Construction | 1 | 06-25-2010 02:49 PM |
| So many questions where to start?!?!(NEWBIE) | painter84 | Painting | 5 | 09-15-2008 01:50 PM |
