Outside Fireplace Not Drawing - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-19-2012, 11:11 AM   #1
outside fireplace not drawing
Smoke pours out of the front of my new outside masonry fireplace. While the smoke does rise through the chimney, a large amout of smoke also comes out the front continuously. The firebox is approximately 72" wide at the opening, 34" high, and 38" deep. The rounded masonry ceiling rises approximately 18" to the 8-foot chimney which is comprised of 17" x 17" masonry flues that are each 2' long (a total of 4 flue pipes= 8'). The chimney is in the center of the firebox.
The fireplace is located approximately 35' from the closest point in my residence to the north. The masonry residence has 10' ceilings with a 10pitch hip-style roof. The 2 adjacent residences are approximately 50' away to the south and west.
The mason temporarily added an additional 2'-17" flue to the chimney (10' total) with no reduction from the smoke pouring out the front.
Any suggestions?
perkinstl is offline   Reply With Quote
Old 12-19-2012, 11:16 AM   #2
Rewards Points: 13,220
http://www.askthebuilder.com/firepla...gn-dimensions/
Old 12-19-2012, 11:27 AM   #3
Rewards Points: 502
Is it possible that the flue itself is in a cold position? If so, it can take a lot longer for the flue to warm up. If the flue is relatively cool, the cool air in it tends to press down on the warmer air from the fire (because the cooler air is heavier) and prevents all the smoke going up, thus forcing it back out of the fireplace opening.
Where I am most domestic construction is masonry, and it is well-known that fireplaces/flues on external walls often don't draw well because they remain damp and cool.
tony.g is offline   Reply With Quote
Old 12-19-2012, 11:35 AM   #4
Thanks for your response. The new fireplace has not been used for any extended period.. so perhaps the flue did not had sufficient time to 'warm-up.
Old 12-20-2012, 08:30 PM   #5
Rewards Points: 1,222
A 17x17 flue is not large enough. In general, the flue needs to be at least 10% of the opening, and that is with a "normal" stack of 15+ feet and not exposed to wind.
72"x34"=2448 SqIn, a 17x17 square flue has an interior working surface area of approximately 177 SqIn (for square flues, you consider it round and use that dimension, which for a square flue is the outside dimension, the thickness of a 17" flue is around an inch, so 3.14159(7.5 squared)=177).
Not much you can do at this point, other than increase the height of the stack and build a small warming fire to heat the flue before you build a normal fire. Personally, I would put gas logs in it and call it good, because without a bigger flue it will always smoke.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 12-21-2012, 08:37 AM   #6
Thank you .
Old 12-21-2012, 12:50 PM   #7
Rewards Points: 502
Also remember that if it is new, the masonry will still contain a lot of water. This will take time to dry out and, in the meantime, will tend to keep the chimney cool.
Old 12-22-2012, 07:26 AM   #8
Rewards Points: 4,526
howzabout mounting an exhaust fan on top to suck out the smoke ?
Old 12-22-2012, 11:14 AM   #9
Concrete & Masonry
Rewards Points: 520
How about a picture or two, the FP opening seems like an odd profile size......You could probably try choking the opening off (width-wise) first to see if that helps, because as Tscar noted, the flues are too small for that big of an opening..........
jomama45 is offline   Reply With Quote
Tags
outside fireplace smoking
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
