Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-05-2012, 12:19 PM   #1
Outdoor fireplace, firewood box upper bracing?
Building an outdoor fireplace, with a firewood box on each side that will hold wood underneath and act as a seating area as well.
The fireplace is going to be all brick exterior.
What should I use to get a rigid structure for the top of the the box?
Should I build a form with wire mesh and pour concrete then brick over?
Should I get a large stone slab to cap each side?
Doing things almost the right way...
Double is offline   Reply With Quote
Old 03-05-2012, 12:41 PM   #2
1/2" steel plate.
Double (03-05-2012)
Old 03-05-2012, 12:45 PM   #3
1/2" steel plate.
...Never would have thoguht of that...
Would you just take your measurement to a local metal shop and have them cut to size?
Old 03-05-2012, 12:47 PM   #4
That's the only way to do it.
I suggested 1/2" so when it gets hot it does not sag.
Old 03-05-2012, 12:50 PM   #5
Excellent, thanks.
I was just thinking, I'm going to elevate the firebox about 12-18" from the pad.
Would you also use a plate over the cinderblock? Or can I simply use flat blockand brick up from there?
Old 03-05-2012, 12:54 PM   #6
Concrete & Masonry
Are you talking about the lintel over the firewood storage boxes, or the firebox itself? Either way, steel flatstock would be one of the last things I would use............
jomama45 is offline   Reply With Quote
Old 03-05-2012, 01:36 PM   #7
And why is that?
jomama is the mason, whatever he suggest on how to do this should work.
Old 03-05-2012, 02:06 PM   #8
My original question was about the firewood storage boxes to support the brick work or stone above the storage space so someone could sit.
My second question was about the need to use anything between the main block base and the bottom of the firebox, or if i can simply lay the fireblock floor right on top of the stone base. I was thinking two courses of cinder block beneath the fire box, but wasn't sure if I needed to lay flatblock on top of that to have a solid base for the floor of the firebox.
Old 03-05-2012, 03:36 PM   #9
Concrete & Masonry
You could pour a concrete top, use one large piece of stone, or if you have room, and angle iron would be a good choice to carry it.
You're building this all on gravel, or some kind of foundation?
Old 03-05-2012, 03:46 PM   #10
I was planning on making a form and pouring a pad over a tampered gravel base, but if you think gravel alone is sufficient that would save on cost.
Old 03-05-2012, 03:55 PM   #11
Concrete & Masonry
No, a 4" concrete pad over well-compacted base would be the absolute min. IMO.
I think you should post a picture/sketch of what you have in mind so we can give you clear answers to your questions.
Old 03-05-2012, 04:05 PM   #12
exactly the same idea as this, but all brick, possibly a stone top to the side "boxes"
Old 03-05-2012, 04:21 PM   #13
My wife wants to replicate this look...
Originally Posted by jomama45 View Post
[ATTACH][/ATTACH]
[ATTACH][/ATTACH]
[ATTACH][/ATTACH]
Although, I don't imagine it will look nearly as professional.
do I need to add top plate bracing on this? oldhouse49 Building & Construction 8 10-28-2011 06:07 PM
post location effect on cross bracing for deck/treehouse? martind74 Building & Construction 1 10-18-2011 01:45 PM
Upper Kitchen Cabinets latemoy Carpentry 3 09-13-2011 07:31 AM
How much bracing for deck posts? jcims Building & Construction 7 08-26-2010 08:58 PM
Roof bracing / pulling rafters together JoeT Building & Construction 8 07-08-2010 08:54 PM
