Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-15-2012, 12:21 PM   #1
Options to repair spalling bricks
I bought a house that had 2 Walls out of 4 with grade above brick Line. i also had a patio with pavers that was sealed with tar, no membrane. the sills in the back of the patio are also partially rotten. 3 rows of brick are now dammaged all around.
got a whooping estimate to repalce the bricks all around, including behind the patio. high cost was justified by usage of many anchors to hold the bricks above...
could i just parge over the bottom rows or pour reinforced concrete over? (i would keep the weep hole open somehow).
ps: i took care last year to drop the ground level last year to clear the top 3-4 inches of foundation.
thanks for your advices,
pp
pascal parent is offline   Reply With Quote
Old 04-15-2012, 12:29 PM   #2
SOunds like you have an issue that needs to be addressed on site.
Good Luck
hammerlane is offline   Reply With Quote
Old 04-15-2012, 03:08 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
theres definitely water damage going on there. and by the sounds of it it not good. this needs to be addressed before it gets even worse and theres no quick cheap fix for it. you have to solve the issue of how the water is getting in first then repair the brick
woodworkbykirk is offline   Reply With Quote
Old 04-16-2012, 10:26 PM   #4
the source of dammage was the high ground level and water in spring time i guess (i'm in canada). i've lowered the ground level since then. now i have to fix it. can i parge over my last 3 rows of bricks? i will then block my weep holes.... which i think is not a good thing.
any ideas?
Siding Options to repair clapboard type siding 30Five Carpentry 7 12-29-2011 02:42 PM
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 10:55 AM
Surface repair spalling chimney bricks. a_gunslinger Building & Construction 3 09-08-2011 07:04 PM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Concrete driveway repair options monkey3605 Building & Construction 5 08-18-2006 04:15 PM
