Old Stone Basement Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-21-2012, 11:32 AM   #1
old stone basement wall
How do i repair an old stone basement wall that is bulging?
burnhr2 is offline   Reply With Quote
Old 07-21-2012, 02:53 PM   #2
Civil Engineer
Rewards Points: 4,520
You start by determining the amount of bulge (you need to measure this with a laser or a builders level). Then you attempt to determine the cause of the bulge. Could be settlement (check this with a builders level or a laser), could be soil pressure, could be the way the wall was built, could be impact. Post some pictures, and the results of your instrument survey.
Daniel Holzman is online now   Reply With Quote
Frame out basement half wall diyinwi Remodeling 6 04-03-2012 10:08 PM
Private Outdoor Courtyard, Wall of Cultured Stone Deeppool Building & Construction 5 12-13-2010 10:56 AM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 01:24 PM
