Old House, No Footings - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-25-2012, 04:44 PM   #1
old house, no footings
I'm doing a home addition in the back of my house with a finished bedroom in the new basement. After the excavation I learned that there are no footings on the existing house. That messes with me a bit because it turns out that the top of the new slab is about even with the bottom of the old house.
I plan on pouring the slab such that it runs under the old foundation by 4" or 5" to give me a bit more of a connection, and I'm also going to pour it a bit high on the old house side (which works out well because my sump is on the opposite (downhill) side of the new addition anyway). I can't just pour the slab higher up because I'm already pretty much at my 7' ceiling height with the slab where it is.
I figure that I'll just try and make as much of a connection as I can between the old and the new (it's not very much, though, and makes me a bit nervous) and instead of trying to fight the water I'll just try and give it an easy path to the sump (via 6" of gravel under the slab).
How can I make the best connection between the old concrete and the new, and what other options do I have as far as keeping water out of my new basement?
DIY1 is offline   Reply With Quote
Old 07-25-2012, 05:02 PM   #2
Civil Engineer
Rewards Points: 4,762
There is no reason to connect the new foundation to the old foundation. You simply place the new foundation as an independent slab or slab plus footings. Connecting to the house has no structural importance. My basement addition is pretty typical, it was built immediately adjacent to the old basement, but has not structural connection, it simply butts up to it, and has a mastic type sealant to prevent water leakage between the two structures.
Daniel Holzman is online now   Reply With Quote
Old 07-25-2012, 05:07 PM   #3
My main concern is waterproofing, not structural. There is only going to be an inch or so of concrete (and mastic) keeping the water out at the seam between the old and the new. That just seems like a recipe for leaks eventually.
Like I said, though, I'm going to try to make it very easy for the water to head towards the sump underneath the slab instead of trying to get up and through that 1 inch barrier. I guess that's about all I can do.
Old 07-29-2012, 02:47 AM   #4
WAS
Illinois home inspector
old house no footings
Strong suggestion: Spend a few hundred dollars and get a qualitied structural engineers opinion.
WAS is offline   Reply With Quote
Tags
footings
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
