Ok To Fill This Block With Great Stuff? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree5Likes
  • 1 Post By de-nagorg
  • 2 Post By Bondo
  • 1 Post By Windows on Wash
  • 1 Post By stadry
Old 01-10-2017, 09:34 AM   #1
Rewards Points: 102
Ok to fill this block with Great Stuff?
I have a crawl space from an addition on my home and on the original block there are some gaps and holes which I would like to fill with Great Stuff.
Is there anything wrong with doing this or is it a good idea for rodents, insects, insulating?
Ok to fill this block with Great Stuff?-img_2716.jpg   Ok to fill this block with Great Stuff?-img_2715.jpg   Ok to fill this block with Great Stuff?-img_2714.jpg
arminius is offline   Reply With Quote
Old 01-10-2017, 09:48 AM   #2
Rewards Points: 1,654
Re: Ok to fill this block with Great Stuff?
If any of that is exposed to direct sunlight, you will be wasting your time and money.
And rodents will probably try to tear through it too.
ED
de-nagorg is online now   Reply With Quote
Old 01-10-2017, 09:50 AM   #3
Rewards Points: 102
ED
None of it is exposed, it was before the addition on the house. I could put some steel wool in there as well.
Old 01-10-2017, 10:02 AM   #4
Is this area leaking air through, from warm to cold?
Steel wool mixed into the foam, will definitely stop the rodentia.
I think that I would mix up some mortar and try to fill those myself, but I don't know how much trouble it will be to get the bucket over to those areas.
ED
Bondo likes this.
The Following User Says Thank You to de-nagorg For This Useful Post:
arminius (01-10-2017)
Old 01-10-2017, 01:45 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,.... I'm with Ed, if yer tryin' to stop critters, I'd go with mortar or grout,....
I'd "Think" mixin' steel wool with the foam would defeat the purpose of both components,...
Windows on Wash and de-nagorg like this.
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Old 01-10-2017, 02:00 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,036
You can use the foam to create a "backstop" for the grout if you want, but I would fill them with mortar if it were me.
de-nagorg likes this.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 01-10-2017, 06:58 PM   #7
Rewards Points: 4,578
rapid setting cement over newspaper stuffed into the hole/cells,,, quik, rodent-proof, cheap, colorfast,,, then again, its YOUR block !
The Following User Says Thank You to stadry For This Useful Post:
great stuff Fix'n it Insulation 3 09-22-2012 10:33 AM
Great stuff around boxes? jamiedolan Electrical 6 12-15-2008 03:07 PM
block foundation shama144 Building & Construction 5 10-27-2008 07:07 AM
Great Stuff question amakarevic Building & Construction 14 01-02-2008 10:28 AM
foam like Great Stuff that is waterproof amakarevic Building & Construction 1 12-30-2007 08:52 PM
