Now That You Solved My Concrete Curing Issue...another Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-05-2013, 03:10 PM   #1
Now that you solved my concrete curing issue...another question
How can I attach full-size brick to the face and top of the low wall/curb, and the somewhat taller planter box? Brilliantine here forgot to place any ties/fasteners in those areas, and I'm not sure mortar will do the job over the long haul (maybe even the short haul).
I did remember to include a small footing for the brick around the base of the planter.
One of the guys at Lowe's suggested Quikrete polyurethane construction adhesive for the back of the brick where it contacts the wall.
Anyone done anything like this, or know anything about it?
Also: should I waterproof the back of that short wall? If so, how?
clambake6 is offline   Reply With Quote
Old 06-05-2013, 06:35 PM   #2
Concrete & Masonry
Rewards Points: 620
If you indeed have a footing around the planter, then there's no need to "adhere" the brick to the concrete wall. A few wall ties installed with Tapcons will certainly suffice. The other short wall is low enough that it wouldn't even require ties.
Another option, if you wanted a true adhered installation, would be to use sawn thin brick, which are generally 1/2" thick and can be set with an appropriate thinset.
Here's a link to one of the larger thin brick producers:
http://www.generalshale.com/products...ype=thin_brick
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
clambake6 (06-05-2013)
Old 06-05-2013, 06:39 PM   #3
Thanks, jomama45
What about trying to waterproof the back side of the wall, any benefit in doing that?
Old 06-06-2013, 06:17 AM   #4
Rewards Points: 4,750
calif's not known for much rain,,, if it were ours, i probably wouldn't,,, but, since its YOURS, you should then you won't be obsessing about it & awaken us all the time now go take a nap & good luck !
Concrete curing question Pawl Building & Construction 5 11-27-2011 08:41 PM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 06:16 AM
2 different conctractors, 2 different concrete curing time estimate Gameboy Building & Construction 3 07-11-2011 01:38 AM
Concrete slab question houdinihar Building & Construction 2 06-07-2006 08:04 AM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
