Is This Now My Rebar Should Look? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-10-2012, 05:00 PM   #16
concretemasonry's Avatar
Rewards Points: 2,608
I hope it is a concrete tub and not just cement.
Dick
concretemasonry is online now   Reply With Quote
Old 10-10-2012, 09:09 PM   #17
Rewards Points: 264
Originally Posted by pwgsx View Post
How is the in ground cement tub coming??
Got a hole and 50, 80 pound bags of crack-resistant concrete.
Waiting on HD to deliver my cement mixer and I ordered a rebar bender / cutter off amazon. I need to get the form built next.
tibberous is offline   Reply With Quote
Old 10-11-2012, 08:25 AM   #18
Rewards Points: 254
What are you doing with this hole? 50 bags? How the hell are you going to do that ?
pwgsx is offline   Reply With Quote
Old 10-11-2012, 09:29 AM   #19
Rewards Points: 264
Plan is to form the rebar, then put an inch of gravel, then pour the floor. Should take 8 cubic feet of concrete to pour 4" deep, so that's 14 bags, and I'll probably go more like 16. Once it sets, I'm going to place in my plywood form, with plastic sheeting over it, and then use as much concrete as I need to do the walls in one pour. Then I'm going to vibrate it, then use a hammer / circular saw to cut out the form.
Does that sound right?
Old 10-11-2012, 11:23 AM   #20
Rewards Points: 254
Ok but you said it needs to be waterproofed? Is it holding water? or what is this for?
Old 10-12-2012, 01:59 AM   #21
Rewards Points: 264
Yeah, it's going to hold water.
Old 10-15-2012, 08:58 AM   #22
Rewards Points: 254
What kinda water? drinking, bath, fish pond?? Cement alone will not hold water......
Size Rebar Needed to Reinforce Bowed Block Wall frtools Concrete, Stone & Masonry 7 06-18-2012 11:28 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 10:48 AM
Rebar for Monolithic Slabs portert0224 Building & Construction 1 07-03-2008 11:37 PM
Rebar Trees trout_baller Landscaping & Lawn Care 5 06-20-2007 05:39 PM
