Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-08-2012, 12:37 AM   #1
Is this now my rebar should look?
Here is a video of guys making a coy pond: http://www.youtube.com/watch?v=ULfm0UQsvo0
My situation is a little different, because I'm using forms to get straight walls, but should my rebar look like theirs?
tibberous is offline   Reply With Quote
Old 10-08-2012, 12:39 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
You did not give pictures to compare with.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 10-08-2012, 12:47 AM   #3
GBrackins's Avatar
so are you building a coy pond or something else?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-08-2012, 01:06 AM   #4
what are you building? if its a basement wall it should look like this.
epson is offline   Reply With Quote
Old 10-08-2012, 01:19 AM   #5
It's a hole guys:
http://i48.tinypic.com/28lz3th.jpg
Outer dimensions on sides and bottom are going to be 4" wider than the form. My plan was to pour the floor first, so I could keep the form off the ground and lined up.
I haven't made the form yet, but I'm guessing it's going to be pretty heavy, because of the amount of 2x4's I'm going to use to brace it.
Old 10-08-2012, 01:23 AM   #6
I think this is different than a basement wall because with a basement wall you only have pressure being exerted inward from the ground. This is going to hold water, so I'd think that would help support it (like the plastic septic tanks you have to floor as you backfill)
Old 10-08-2012, 08:22 AM   #7
Concrete & Masonry
If it was mine, I'd either install a one-piece rubber liner under the slab and over the sides terminating it under what will eventually be you're "coping". Another option would be to place a pvc "waterstop" strip into the slab pour and use your "pool paint" on the interior of the tub.
As for rebar, it won't look like that unless you're going to be doing gunnite/shotcrete.........
jomama45 is offline   Reply With Quote
Old 10-08-2012, 04:16 PM   #8
He is trying to build a cement bathtub in his basement floor
How do I pour an in-ground concrete tub?
Waterproofing a concrete box?
pwgsx is offline   Reply With Quote
Old 10-08-2012, 05:17 PM   #9
Old 10-08-2012, 05:19 PM   #10
WHAT IS IT FOR???
Bathtub?? Where is the plumbing?? A fish pond?? How will you drain it?? 1 person swimming pool?? That water will be nasty!!
Old 10-08-2012, 05:44 PM   #11
WHAT IS IT FOR???
It's for a reservoir. Plumbing is a non-issue. I just need to it hold water and not crack.
Old 10-08-2012, 06:18 PM   #12
Concrete & Masonry
It will work, as long as you don't rely on the concrete itself to be waterproof......
Old 10-08-2012, 06:19 PM   #13
Like emergency water storage? Why not come out with the whole story so people can give ideas?
Old 10-08-2012, 07:04 PM   #14
concretemasonry's Avatar
You will need a lot of small rebar spaced closely with complete long splices/laps and a regulate(sp?) cast into the slab and wall. The closely spaced steel will minimize the amount and size of cracks. The square intersection with the slab and walls is asking for trouble. - That why few reservoirs or storage tanks are square unless they are precast and monolithic concrete.
You can get a better solution by digging a hole and having someone stick in a precast tank/utility vault and plug excess openings. After you dig the hole and put is some rock. it a few hour job to deliver, set and then you just do your thing. If it does not have to be huge and square, there are many options to use large precast manhole sections depending on your desired depth and volume - like a cistern.
Dick
concretemasonry is offline   Reply With Quote
Old 10-10-2012, 05:23 PM   #15
How is the in ground cement tub coming??
Size Rebar Needed to Reinforce Bowed Block Wall frtools Concrete, Stone & Masonry 7 06-18-2012 12:28 PM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Rebar for Monolithic Slabs portert0224 Building & Construction 1 07-04-2008 12:37 AM
Rebar Trees trout_baller Landscaping & Lawn Care 5 06-20-2007 06:39 PM
