-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Is this now my rebar should look? (http://www.diychatroom.com/f105/now-my-rebar-should-look-159347/)
tibberous 10-07-2012 11:37 PM
Here is a video of guys making a coy pond: http://www.youtube.com/watch?v=ULfm0UQsvo0
My situation is a little different, because I'm using forms to get straight walls, but should my rebar look like theirs?
gregzoll 10-07-2012 11:39 PM
You did not give pictures to compare with.
GBrackins 10-07-2012 11:47 PM
so are you building a coy pond or something else?
epson 10-08-2012 12:06 AM
what are you building? if its a basement wall it should look like this.
http://www.basementexpert.co.uk/grap...0rebar%203.jpg
tibberous 10-08-2012 12:19 AM
It's a hole guys:
http://i48.tinypic.com/28lz3th.jpg
Outer dimensions on sides and bottom are going to be 4" wider than the form. My plan was to pour the floor first, so I could keep the form off the ground and lined up.
I haven't made the form yet, but I'm guessing it's going to be pretty heavy, because of the amount of 2x4's I'm going to use to brace it.
tibberous 10-08-2012 12:23 AM
I think this is different than a basement wall because with a basement wall you only have pressure being exerted inward from the ground. This is going to hold water, so I'd think that would help support it (like the plastic septic tanks you have to floor as you backfill)
jomama45 10-08-2012 07:22 AM
If it was mine, I'd either install a one-piece rubber liner under the slab and over the sides terminating it under what will eventually be you're "coping". Another option would be to place a pvc "waterstop" strip into the slab pour and use your "pool paint" on the interior of the tub.
As for rebar, it won't look like that unless you're going to be doing gunnite/shotcrete.........
pwgsx 10-08-2012 03:16 PM
He is trying to build a cement bathtub in his basement floor :no:
http://www.diychatroom.com/f105/how-...te-tub-158616/
http://www.diychatroom.com/f105/wate...te-box-158755/
tibberous 10-08-2012 04:17 PM
pwgsx 10-08-2012 04:19 PM
WHAT IS IT FOR???
:whistling2: Bathtub?? Where is the plumbing?? A fish pond?? How will you drain it?? 1 person swimming pool?? That water will be nasty!!
tibberous 10-08-2012 04:44 PM
Originally Posted by pwgsx (Post 1026676)
WHAT IS IT FOR???
It's for a reservoir. Plumbing is a non-issue. I just need to it hold water and not crack.
jomama45 10-08-2012 05:18 PM
It will work, as long as you don't rely on the concrete itself to be waterproof......
pwgsx 10-08-2012 05:19 PM
Like emergency water storage? Why not come out with the whole story so people can give ideas?
concretemasonry 10-08-2012 06:04 PM
You will need a lot of small rebar spaced closely with complete long splices/laps and a regulate(sp?) cast into the slab and wall. The closely spaced steel will minimize the amount and size of cracks. The square intersection with the slab and walls is asking for trouble. - That why few reservoirs or storage tanks are square unless they are precast and monolithic concrete.
You can get a better solution by digging a hole and having someone stick in a precast tank/utility vault and plug excess openings. After you dig the hole and put is some rock. it a few hour job to deliver, set and then you just do your thing. If it does not have to be huge and square, there are many options to use large precast manhole sections depending on your desired depth and volume - like a cistern.
Dick
pwgsx 10-10-2012 04:23 PM
How is the in ground cement tub coming??
