IS It Normal For It To Take Over A Week For Concrete To Dry? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-21-2013, 01:14 AM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
IS it normal for it to take over a week for concrete to dry?
A week ago I poured some concrete over a new drain line I added leading to my sump pit. It's been probably over a week now, and while it has hardened, I can still scrape at it with my finger nail.
Is this normal, or should I start to worry it wont cure at all? I will admit I did not do the best job with this, all I had was a small bucket, and the bag just said to put 0.8 gal of water per bag, but I could not really measure with what I had so I was adding water till it seemed like the right consistency, and I could only do a small batch at a time so each time I poured it was probably not 100% the same consistency. I used some bags I had in my garage already, and it's parging cement, so maybe not the best for this but figured it should work ok, right?
Day it was poured:
Today: (guess I should have used the same camera, this one is taken with my phone)
Also does temperature have a big factor? Should I be pointing a heater on this with some fans? I normally have the thermostat programmed to around 13 degrees when I'm not home or sleeping.
Old 02-21-2013, 03:32 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Being just a dumb painter, I would probably throw some heat and a fan on it.
13 degrees
Old 02-21-2013, 04:41 AM   #3
Rewards Points: 582
As OPC hardens by curing rather than drying I wouldn't bother with any extra heat.
We don't have the name parging cement here, but I'm guessing it may contain lime which slows down the hardening a bit. Old bags of cement also sometimes need extra OPC in the mix. Give it another week or 2.
stuart45 is offline   Reply With Quote
Old 02-21-2013, 05:07 AM   #4
Rewards Points: 4,656
conc doesn't dry, it ' cures ',,, while curing, its exothermic as its chemical reaction of lime & wtr produces heat
sounds like too much wtr so what's the worst thing that can happen ? you take it out & replace it next time use the right stuff - you can even buy it at the apron/vest stores - its called quikrete, sakrete, or pre-mix'd-krete-in-a-bag
another guide - DON'T ADD TOO MUCH WATER MEASURE the water, too
this thread's fun
Old 02-21-2013, 06:01 AM   #5
chrisn's Avatar
Rewards Points: 394
said I was dumb
Old 02-21-2013, 06:55 AM   #6
DIY staff
Rewards Points: 7,174
13 Celsius = 55 Fahrenheit
Parging cement is a covering for an existing brick or concrete wall----it is not designed for use as a floor--
I suggest you remove that and use a concrete mix----
joecaption (02-21-2013)
Old 02-21-2013, 04:40 PM   #7
Wire Chewer
Rewards Points: 126
I was afraid of that... so think it's just going to stay this way and not cure at all? Since if it's just going to take longer, I'm patient and can wait... I guess I would not have to take it ALL out would I? I could just take a few inches and then just pour some proper concrete on top? The dirt I was able to just throw beside the house as it's just sand there anyway, but concrete, I don't really want to do that with, so I'd have no way of disposing of this. There's some excess that formed in blobs that I had just pushed to the side to pickup later, and it crumbled in my hands when I squeezed it just now, so I have a bad feeling I will in fact have to redo it all.
Old 02-21-2013, 05:33 PM   #8
DIY staff
Something is wrong with that product-----it should have set up long ago----remove as much as you can---it went bad and may never set up----
Old 02-21-2013, 05:51 PM   #9
Wire Chewer
Rewards Points: 126
Ok, that's what I'll end up doing then. Really I should have bought new from the start instead of taking my chances.
Old 02-21-2013, 06:49 PM   #10
DIY staff
I have a problem storing powders-----the humidity here is high and they go bad in a few months-----
coolant indicater staying cooler than normal raptor99 Automotive Repairs 5 02-16-2010 03:19 AM
laminate floating floor squeeky, is it normal? gagaliya Flooring 1 10-02-2009 05:27 AM
How much corrosion is normal? PirateKatz Plumbing 1 02-09-2009 10:58 AM
Hello from IA ZooKeeper General DIY Discussions 5 12-02-2007 08:11 PM
Is a big price difference normal? chevyguy1973 Roofing/Siding 5 02-08-2006 10:06 PM
