Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-10-2012, 11:22 AM   #1
Noises from wall
i hear loud cracking noises from my ist story house ,usually it happens when its cold outside as temperature warms up the noises disappear.second i saw a little bit of staircase crack in outisde brick wall which i repaiered once but it again appered but almost hairline( also i see a meatl piece inside too may be its the tie) .this crack is though away from the noise generating corner .i will post pictures too to get a better understanding of what is happening from u guys. any help how to proceed further is appreciated
thx
computerxtutor is offline   Reply With Quote
Old 04-10-2012, 11:37 AM   #2
Noises from wall
Stair case cracks are most often caused from the footing settling, and I've never heard them cause any sort of noise.
Is there trusses or site built rafters in the attic?
Old 04-12-2012, 11:25 AM   #3
Noises from wall
thanks can u explain what thses means. trusses . outside i see no crack in foundation
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
