Newly Poured Driveway - Issue? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-03-2013, 08:39 PM   #1
Hi all, newbie here! I have a newly poured driveway, which is approximately 2 months old. I have just recently noticed what I would call ripples, running through part of the concrete. Any idea what these would be from or think I should be concerned? I have done a little research and the best I could come up with is rebar vibration. I am not confident in this research so I wanted to see if I could get any other opinions. I live in the Midwest and it was poured during temperatures right around the freezing mark, not sure if this has anything to do with it. A ground heater was used for 3 days prior to the pour and blankets were utilized after the pour.
Any ideas, thoughts, suggestions?
black95fiveoh is offline   Reply With Quote
Old 04-03-2013, 08:44 PM   #2
Rewards Points: 960
I've never seen that or heard of it, but that does look like a grid. Do you know if the flatwork company used re-bar? Have you asked them about the look of it?
Is there a problem, other than you don't like the way it looks?
We usually do a light-medium brush finish perpendicular to the length. I can't see very well what type of finish you got.
cleveman is offline   Reply With Quote
Old 04-03-2013, 08:53 PM   #3
Concrete & Masonry
Rewards Points: 620
That looks like marks left from the blankets to me. Not sure from the picture if they're just topical, or if they have some depth. One of a few reasons I won't even think of pouring a driveway in the middle of winter unless of course it's only temporary..............
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 04-03-2013, 09:03 PM   #4
From what I know, rebar was used. It is a light brushed finish perpendicular to the pour, as you describe. At this point the only issue is I really don't care for how it looks, but as long as it isn't going to affect the longevity of the concrete, I could probably live with it.
Old 04-03-2013, 09:06 PM   #5
The marks are raised, which is what led me to believe it was caused by something below the surface, like rebar.
Old 04-03-2013, 09:16 PM   #6
joed's Avatar
Rewards Points: 13,298
Turn the picture right side up.
Old 04-03-2013, 09:18 PM   #7
I am not sure why it rotated, slightly annoying I know. I will try and post a better pic.
Old 04-03-2013, 09:21 PM   #8
It sure don't look good!
Hardway is offline   Reply With Quote
Old 04-03-2013, 09:27 PM   #9
Not at all
Old 04-03-2013, 09:50 PM   #10
Rewards Points: 960
I don't care for the surface very much.
You must have a problem with aggregate in your area. We have the same problem here as well. The aggregage pops.
But the surface looks almost like it got washed out. Hard to tell from the photo.
Thanks for rotating the photo by the way.
Old 04-04-2013, 05:08 AM   #11
Rewards Points: 4,732
anyone explain ' rebar vibration ' to moi ?
other'n cosmetic ( which to my bride, nagzilla, is enough reason for her to bomb the n koreans ), looks fine & sounds as if it was properly plac'd,,, like jomama, i'm not wild about placing in cold weather but not happy about hot weather either
Old 04-04-2013, 06:29 AM   #12
If the marks are raised I would lean towards the rebar being to close to the surface. When rebar or wire is to close to the surface it tends to raise the crete ever so slightly when you wipe out the the slab.
concreteman is offline   Reply With Quote
Old 04-04-2013, 10:32 AM   #13
Rewards Points: 3,718
I agree with jomama,and his reasoning about pouring flat work in freezing weather, this is a good example of why not to do it.
Canarywood1 is offline   Reply With Quote
Old 04-04-2013, 09:59 PM   #14
Rewards Points: 960
Those also look like something I might leave behind with my trowel-on-a-stick. This would also explain why they end abruptly. The finishers broomed over the area where you don't see the marks, and left other areas unbroomed.
Old 04-05-2013, 12:44 AM   #15
Rewards Points: 626
That is rebar! They might have tried to float it in or they did not set at the right depth, or did not scree it right. what ever the problem they need to come out with a jack hammer and redo your driveway.
Nailbags is offline   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 03:59 AM
Illuminating a Driveway diydude1 Electrical 16 04-12-2012 08:24 PM
120' long concrete driveway WillK Building & Construction 4 04-01-2011 09:58 AM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 07:07 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
