New Pool Coping Installation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-04-2016, 12:04 PM   #1
Rewards Points: 4
I have been following the great post by Knucklez detailing his Pool Coping project and I had a few questions on my very similar installation. I will have a concrete deck butting up to 3.5 wide x 2.24 high x 9 inch long bull nose coping with an expansion joint in between. I'm in the process of pouring a concrete base about 12 inches wide x 6 inches deep reinforced with rebar that bridges across the deck supports because I don't trust my back-fill. I was planning on bridging across the back-fill with the concrete deck as well. I'm thinking of two options. Option 1 below shows rebar spanning from the coping base to native ground which would tie the coping base to the concrete deck. Option 2 shows the coping base and the deck with the rebar separated as to let the deck float from the coping base. Some pics are included below of the build. I was planning on using a modified thinset for adhering the coping around pool walls. I'm wondering what I should on the stairs since most of the coping blocks would be sitting on the plastic but need to be space up about 3/8 of an inch to match the height of the other blocks. Any advice would be greatly appreciated.
New Pool Coping Installation-option1.jpg   New Pool Coping Installation-option2.jpg   New Pool Coping Installation-2016-11-28-15.25.03.jpg   New Pool Coping Installation-2016-10-24-15.25.13.jpg   New Pool Coping Installation-2016-12-04-09.15.19.jpg
Barnon is offline   Reply With Quote
Old 12-08-2016, 08:20 PM   #2
Licensed Engineer
Rewards Points: 171
Re: New Pool Coping Installation
In both plans your re-bar is too low. You should position it below the slab upper surface at a depth equal to 1/3 of the slab thickness. If you use a 3-1/2 in thick slab the reinforcement should be approximately 1 inch below the surface, for a 6-inch slab position it 2 inches below the upper surface. I don't see anything wrong with extending the reinforcement in the paver base pour into a thickened edge of the deck pour. Extending it a foot into the deck pour for your application should be fine.
Eliminate the two notched edges on the bottom of the deck slab. Both will only become stress points generating cracks that will completely encircle your pool. Keep a smooth bottom surface on the deck slab and use isolation board if necessary if there is no way to eliminate a notch.
Nice looking pool! Who is the manufacturer? Our steel wall pool is a Kafko product.
MI-Roger is offline   Reply With Quote
The Following User Says Thank You to MI-Roger For This Useful Post:
Barnon (12-09-2016)
Old 12-09-2016, 08:16 AM   #3
Rewards Points: 4
Thanks for your response.
I doubt they are the mfg but I bought the kit from Royal Swimming Pools.
Seems the only way I can eliminate the notch at the edge of the coping base, since it's already poured, is to build it like the drawing below. Will this work?
Old 12-23-2016, 06:15 AM   #4
Rewards Points: 70
You are doing really good work. Pool looks very nice!
harrisong35 is offline   Reply With Quote
Old 12-23-2016, 10:49 PM   #5
Msradell's Avatar
Rewards Points: 84
Question
How thick would the concrete be in this scenario?
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Looks like it's time for a new pool pump; please advise! a1481155 Plumbing 5 08-07-2013 05:14 PM
Re-Wiring Above ground pool DTZee Electrical 36 05-08-2013 05:18 PM
Geothermal heat pump using pool as heat sink mnschu HVAC 9 05-17-2012 09:10 PM
Electrical run to new pool house AlwayzSomethin Electrical 11 04-26-2012 02:47 PM
Movement of cement pool deck around inground pool sgagnier Landscaping & Lawn Care 1 07-05-2010 01:31 PM
