New Patio - Pour Over Existing Or Demo? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-19-2013, 08:09 PM   #1
New Patio - Pour over existing or demo?
Please see image: http://www5.picturepush.com/photo/a/12727518/img/12727518.gif
Questions:
Should we pour over existing patio, stairs and footers?
If not, why?
If so, what prep work should be done to the existing concrete and how do we ensure the new concrete doesn't crack around the existing? My gut is telling me the new will settle more and cause cracking around the border of the old.
Thank you!
LB
LBtechnology is offline   Reply With Quote
Old 04-19-2013, 09:04 PM   #2
Rewards Points: 12,878
That drawing tells us nothing.
What's wrong with the old slab?
Trying to lay a new slab over an old failing slab never works out.
Old 04-19-2013, 09:13 PM   #3
There's nothing wrong with the old slab and it's the original from 1987.
The drawing shows the general dimensions and the layout of the concrete in question.
You are a welcoming kind of guy, huh?
If you join a web development forum to ask questions, maybe I'll be able to welcome you the same way.
Old 04-20-2013, 06:22 AM   #4
Rewards Points: 4,454
wouldn't say ' never ' but overlaying the old slab after installing the new conc would probably be a better solution,,, the o'lay's only 1/8" thick so that shouldn't be a problem.
still important to know WHY the old slab's failing & how that's evidenced,,,
not that joe needs any defense as this topic's been address'd many times previously,,, IF i'd gotten to this thread yesterday AND been in the same mood as then, my reply would probably have been deleted by a more forgiving moderator as it was yesterday,,, many times threads are begun to validate the op's incorrect method/materials/etc,,, some tire of that sooner than others & more easily
Old 04-20-2013, 06:53 AM   #5
DIY staff
Rewards Points: 7,174
I'm not a concrete guy--but I've got enough experience to offer an opinion---
Your new slab will not 'float' as it is fully supported by the footers-----if the old slab is supported the same way---your idea might work---
However, If it is a floating slab----which is typical of a patio---it will move more than the 'fixed' 'slab and a crack may form around the old slab as it moves---
Don't be to hard on Joe----He's not long on words sometimes--but he is asking for useful information----
LBtechnology (04-22-2013)
Old 04-20-2013, 07:03 AM   #6
as mike mentions, there will be a separation line showing between the old AND new conc,,, pay attn to design, interpretation, AND a good jnt pattern,,, these are critical to not hearing about failings from your bride
Old 04-20-2013, 07:08 AM   #7
joed's Avatar
Rewards Points: 11,608
Pouring over old concrete has in my experience always resulted in cracks in the new at the same place as the old work or cracks at the edge of the old work.
The Following User Says Thank You to joed For This Useful Post:
Old 04-20-2013, 07:19 AM   #8
think joed's right,,, unless reflective cracking is properly address'd, the old crks can make a mess of the new conc,,, while that's his experience, ours is different,,, consider a bonded OR unbonded o'lay - also hybrid-polymer-modified cementitious thin o'lay
IF hgwys/parking lots can be successfully ' whitetopped ', i see no reason your project would be unsuccessful IF you're knowledgeable about the work,,, showing us here asking ?'s suggests differently
Old 04-20-2013, 10:27 AM   #9
I couldn't find any issues with the old slab. The existing footers from the old wood deck seem fine and so do the stairs. One of the stairs was crudely cemented to the existing patio so that will probably need to go.
We were told that the existing concrete patio is more than likely pinned to the foundation and that the same should be done with the new regardless of pour over or demo.
We are trying to determine whether we should pour over some, all or none of the existing concrete patio, stairs and old concrete footings.
joed - appreciate the answer
oh'mike - sounds like good info to me
itsreallyconc - Your font is difficult to read.
joecaption - I was ribbing, not kicking. But I have a feeling you realized that.
Old 04-20-2013, 10:54 AM   #10
too bad as it was a really good response we do this work for a living
Old 04-20-2013, 11:35 AM   #11
itsreallyconc - I really do appreciate your help and help from others, but fonts like yours make reading forums difficult and pages messy.
Check out responses from joed and oh'mike - easy to read and they answered questions without any unnecessaries.
Old 04-20-2013, 01:23 PM   #12
Concrete & Masonry
Rewards Points: 470
I wouldn't pour over any existing slab or structures UNLESS I got 4" minimum gravel between the two to ensure separation. BUT, frost concerns are obviously a much larger concern here.........
jomama45 is offline   Reply With Quote
Old 04-22-2013, 03:28 AM   #13
you don't place any bonded overlays, joe ? not just poly-mod'd thin but 4" or 6", either ? ? ? that 4" separation - lateral OR vertical ? ? ? tnx, j
Old 04-22-2013, 03:33 AM   #14
LB, you know what i forgot ? your slab should NEVER be attached to your structure,,, sorry for the brain****,,, ooops, forgot you won't read this 'cause its ' messy ' - darn
oh'mike clearly sez he's not a concrete guy,,, even i read that part easily
Old 04-22-2013, 02:19 PM   #15
I agree, it shouldn't be connected and we will use an expansion joint. We will also remove all existing concrete and make sure the ground is prepared properly and the final slab has the appropriate grade. Now we need to consider stamping, texture, color, etc., or if we want it to be nice and simple concrete.
Now I have a good enough grasp to make a decision on the best company to hire.
Appreciate all the feedback.
itsreallyconc - I don't understand your purpose of using a font that is difficult to read and makes the page messy. That doesn't mean I didn't read what you had written.
Enclosed porch over existing concrete patio? Pat the Rat Concrete, Stone & Masonry 2 06-10-2012 10:09 PM
Anchor pergola to existing patio Fotini Building & Construction 1 06-08-2012 02:28 PM
Build a covered patio on existing slab Dornier Building & Construction 12 03-21-2011 07:55 PM
screening in an existing patio jamesbalog Building & Construction 1 03-04-2011 12:41 PM
Landscaper to Pour Concrete For Patio? tibetie Landscaping & Lawn Care 2 11-24-2010 10:43 PM
