-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   new hole for dryer vent in cinder blocks (http://www.diychatroom.com/f105/new-hole-dryer-vent-cinder-blocks-178411/)
jobblyman 04-29-2013 09:53 PM
3 Attachment(s)
I'd like to move the exhaust vent for my gas dryer. I'd like to make a new hole in my basement wall and patch up the old hole. The basement walls are cinder blocks from 1966. Currently the dryer exhausts right under my sliding door and under my soon to be deck. I'd like to point it out the side of the house.
To vent out the side wall, the hole out would have to be in the first block from the corner. Any further in from the corner is blocked by HVAC ducts. I'd also still like the exhaust to be some what behind the dryer, as I don't want to change the orientation of the dryer.
Is there a problem with cutting a hole in the corner block? Will it some how affect the structural integrity of the wall? Last thing I need is the house coming down on me.
Please see the pictures below. Any comments/suggestions are appreciated. Thank you for reading and your help.
gregzoll 04-29-2013 09:57 PM
I would not place it that close to the a/c unit. I would go higher up to the ledger above the cinderblock, than go through the block.
RWolff 04-29-2013 10:14 PM
The hole in the corner shouldn't be a problem, and if you honestly had to worry about a 4" hole there causing your house to come down, I'd worry a lot about being there!.
If you can cut the hole out that's best, rather than trying to break it out with a chisel.
jobblyman 04-29-2013 10:18 PM
Thanks for the replies. That AC unit is old, seldom used, and will be replaced sooner than later. I feel it's too close to the house to begin with, but it was here long before I was.
The rim joist is a 2 x 10. My understanding is a hole cannot be larger in diameter than 1/3 the size of the joist. For a 2 x 10 I figure that's 3-5/32". A dryer vent is 4", so it's my understanding the hole would be too big. Perhaps that would bring the house down!?
I like the idea of cutting a hole best, I tend to butcher with chisels. Might be best to hire that out to somebody with a large bit than buy one...
RWolff 04-30-2013 12:40 AM
The rim joist is resting fully supported on that block wall, no? the risk of over cutting a JOIST concerns those freespanning across the room, and you don't want to cut the bottoms of those in any way either, but the rim joist if it's supported on the block wall is different.
Keep in mind it takes a lot more than a 4" hole in the wall to "bring a house down"!
This reminds me of a woman who bought several sculptures from me, then afetr she got them she emailed that she thought they were too heavy for her wall so she gave them to a friend for her garden.
I had to write back that the weight of a wall and it's strength is far greater than she thinks, and that a 40# sculpture is NOT going to be too heavy for the wall, the wall holds the roof, snow and more up, 40# is nothing it's another sheet of sheetrock in weight.
Cutting/drilling is better than pounding on the block with a hammer and chisel- that tends to crack the block and can loosen it.
stadry 04-30-2013 05:04 AM
why are we talking rim joist when the hole's thru block ? what'd i miss ?
try a 5/8" bit w/bulldog class hammer drill - cheap to rent compared to conc cutter's min charge
RWolff 04-30-2013 08:21 AM
Someone suggested going higher up to avoid having to go thru concrete, to which the OP said:
The rim joist is a 2 x 10. My understanding is a hole cannot be larger in...
Can't always do that without a bunch of elbows to get the vent up in that area under the floor, or using flex vent hose.
Here's all he needs since he is only drilling the one hole thru the block one time, and his vent is sheet metal so a 4" bit should work: $16.99 at Lowes, there's better bits but since this is aone-time job why spend $80 on a better bit.
Kobalt Carbide-Grit Hole Saw Kit
Item #: 322704 | Model #: 9228
Cuts Granite/Masonry Yes
4" HoleSaw, Mandrel and Pilot Bit.
Can get the next larger size to be sure, 4-1/8" maybe available, but for under $20 there's a holesaw to do the hole.
