New Construction-Vapor Barrier - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-16-2014, 03:46 PM   #1
New construction-Vapor barrier
New construction/cabin in MI
5' block crawlspace
I plan to put 6mil plastic against the outside of the block before backfill. I will then put an R5 insulation on inside of foundation wall. I have 6mil on the floor covered with stone. I may pour a floor someday, but not necessary now.
Is this a good moisture proof method?
I will be providing a fan/ventilation to the crawl space also.
Scott
Flyingmonkey is offline   Reply With Quote
Old 04-16-2014, 04:42 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
5' block crawlspace
Scott
Ayuh,.... You'd probably be better off with a tar sealant, 'n the waffle plastic liner on the outside,...
The Following User Says Thank You to Bondo For This Useful Post:
joecaption (04-16-2014)
Old 04-16-2014, 07:11 PM   #3
Rewards Points: 12,808
6mil. would be way to thin and get destroyed when back filling.
Now's the time to also add the needed drain tiles (French drain) before the crawl space fills with water and have to do it later.
Old 04-16-2014, 07:21 PM   #4
landfillwizard's Avatar
Rewards Points: 498
Is there some reason you didn't add 2 more courses of block so a person could walk around under the cabin?
landfillwizard is offline   Reply With Quote
Old 04-16-2014, 08:59 PM   #5
I went 5' because elevations called for it. I was going to go 4' but gave myself some more room.
I have interior drain tile and a sump pit. We are on sand/gravel and I'm not worried about water much...just typical moisture.
So, what type of construction is my house Tonglebeak Building & Construction 8 12-01-2012 11:45 AM
Books that teach the basics of construction - recommend them to me? costafinkel Building & Construction 13 08-05-2011 12:32 AM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 07:05 PM
