Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-29-2012, 06:47 PM   #16
New Concrete On Top of Old
Originally Posted by St. A View Post
Last question and then that's it (until the next time ): Should I anchor the sleepers to the concrete? If so, with what? Thanks again all. -Aaron
Any construction adhesive will work,and it's an easy way to anchor them.
Canarywood1 is offline   Reply With Quote
Old 12-29-2012, 07:36 PM   #17
Moderator
kwikfishron's Avatar
If you're going to pour a slab you should bust out and remove about a third to a half of what you have now on the high side. As mentioned 7 1/2 to zero is a bad plan.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 12-29-2012, 08:10 PM   #18
I have decided to go with the sleeper method, at least on the interior project. My intention was to do concrete, vapor barrier barrier, sleeper, ply sub-floor. A construction adhesive would just adhere my sleeper to the vapor barrier and not to the concrete. Would you put the vapor barrier elsewhere?
St. A is offline   Reply With Quote
Old 12-29-2012, 09:36 PM   #19
In that case a ramset would work,or maybe tapcons.
Old 01-04-2013, 10:09 PM   #20
Guywithskills
I have done lots of pours over old concrete for a variety of reasons. Tried lots of "quick solutions." My experience says, if you pour over old, the cracks and joints will mirror up no matter what you do. That is guaranteed. You will not bond to it. It is all we could do to bond to Cool Decking around a pool that was already rough, TSP washed and acid washed.
If the old slab is without cracks and decent shape, pour the new one, match the expansion joints up exactly by marking so they can be seen to follow after the new poor place 15lb roofing felt over old slab. If old slab has cracks, we bust it up with an 8lb sledge hammer into 8" pieces approximately, actually not that hard. Takes an hour for a 10' x 20' slab. If it is especially hard, use a pry bar and just leverage the slab up a couple of inches and start at the far end and break your way to the lever. This works very well and Ive seen lots of guys in the trade use this. We were not the only ones. Dont pull it up, you are just breaking it up and leaving in place. Then lay 15lb felt over and pour your new slab. You do not want it binding to the old and you can put your expansion/cut joints where you please. This will give a good result. In the early days of my concrete life in the 70s, we tried probably all the short cuts. The real labor is in breaking up the old. Like I said, maybe an hour of sledge hammer. If out of shape and fortunate enough to not have to do such hard labor, bring a buddy and trade off. Charge him $20 for the work out...
Guywithskills is offline   Reply With Quote
Old 01-05-2013, 06:41 AM   #21
interesting - yes, crks/jnts do reflect - that's why there are specific respective methods, tools, & mtls to deal w/'em,,, we routinely overlayed conc & never had any debonding issues - i think the success is due to 3 parts: 1, choosing the right mtls; 2, proper repairs & surface prep; & 3, having artisans w/necessary skill.
kool-dek type mtls require more prep than tsp ( mild acid ) & ' acid washed ' it also helps knowing different types of overlays ( bonded, unbonded, thin, decorative ), & proper mtls avail to do the work - usually NOT found at apron/vest store
' lots of guys in the trade ' isn't a ringing endorsement to me unless the trade is ' hacking ' there are specific guidelines for when / where to place contraction jnts,,, expansion joints aren't rqd in a slab - perhaps an isolation jnt
another point - we still own 8, 12, & 16# sledge hammers but they rarely see any use - for $60, rent a bosch brute electric jackhammer if you want a workout, go to a gym
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 06:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
