12-28-2012, 07:01 PM
#1
New Concrete On Top of Old
I touched on this topic in another thread, but thought this title would get right to the point. I'd like level an existing concrete foundation which was graded rather steeply at 7 1/2'' over an 18' run. I'm looking at doing this in two locations- one under the house (carport), one on a concrete parking area. I'm thinking of cleaning the old concrete, drilling some holes in it, adding rebar to help reduce any shifting, and then call in a truck for the pour. It looks like it would be about three yards in each location. How does this manner of leveling sound? Thanks- Aaron
12-28-2012, 08:05 PM
#2
journeyman carpenter
if you have done your calculation right on the volume you should be fine.. just be sure to strike a level line with a laser level so to have something to finish to
12-28-2012, 08:22 PM
#3
would you touch on this a bit more 'cause i just got in someone poured a footer that's 7 1/2" LOW on 1 end 18' from the correct elevation ? ? ?
obviously having the conc contractor come back isn't an option ? then again, i he hadn't noticed the forms had fallen OR didn't use a level, why would you want him back,,, 'cleaning the old concrete' may involve scarifying or using a bushing tool, mortar for a bonding compound to prevent old conc from sucking moisture out of the new, vertical rebar 2' o/c + horizontal #4 bar tied to the vertical bar,,, anyway, that's my story & i'm stickin' to it
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
12-28-2012, 08:23 PM
#4
Master General ReEngineer
Ayuh,.... 'n you shoulda stuck with that thread,...
You've only answered a few of the questions asked of you, There....
Now yer runnin' another thread, 'n Nobody has a clue as to what yer talkin' 'bout....
If ya run 1 thread 'bout the project phase, All the relevant info is where it can be referenced...
New thread,... No reference,.... equals Confusion....
Btw,... I asked ya another question in yer 1st thread....
12-28-2012, 08:54 PM
#5
There's no contractor to call as the work was done years ago before I owned the house. But in any case, there is no fault, the concrete was graded, presumably for drainage away from the house. I just want to level part of it so I can build something on top of the level foundation. Thanks- Aaron
PS- Spanked about starting a second thread. Wasn't trying to break any rules of etiquette here. I was just trying to help by simplifying the question. On other forums where I am an active member, I know users often search for subjects by title and I thought clearing up mine would aid in other people's searches. Sorry for any confusion I may have caused. Thanks for your help- Aaron
12-29-2012, 07:20 AM
#6
is this a buried wall OR slab ? maybe a picture's a good idea
forget those other forums - ALL the good guys are here
12-29-2012, 07:57 AM
#7
What is it you want to build? Your slab isn't a "foundation" and likely has no footers.
12-29-2012, 08:22 AM
#8
Ayuh,... Click on the links in post #4 to find his Other thread, with all the Information...
12-29-2012, 12:28 PM
#9
Not a good idea to go from "0" to 7 1/2 inches,the "0" end should be at least 3 inches thick,and a good bonding agent applied for 3-4 feet.
12-29-2012, 12:56 PM
#10
Canarywood- Thanks for your reply. Is the feather edge always a bad idea? If it is an issue of traffic/ weather, would thinset/ tile over the top mitigate the degradation problem or is it another issue like brittleness in the thin feateredge? Thanks again, Aaron
12-29-2012, 01:11 PM
#11
Feathering to "0" is always a bad idea,and thinset and tile would not mitigate the degradation problem,i've never seen it work in my 35 years in the business.
12-29-2012, 01:21 PM
#12
Thanks Canarywood. I sure appreciate the information. I asked another similar question in another section of the forum- basically using sleepers over vapor barrier over concrete to attempt the same thing- a level floor for a living area. If you have the time, I'd be curious if you'd ever seen this or another solution to this problem. -Aaron
Small Wood Shop on Grade
12-29-2012, 01:27 PM
#13
Framing Contractor
We have done that before. Cheaper than the concrete also. I didn't read the other thread so I am just going by what you have here.
12-29-2012, 03:42 PM
#14
[quote=St. A;1081868]Thanks Canarywood. I sure appreciate the information. I asked another similar question in another section of the forum- basically using sleepers over vapor barrier over concrete to attempt the same thing- a level floor for a living area. If you have the time, I'd be curious if you'd ever seen this or another solution to this problem. -Aaron
That would be a much better and a lot cheaper solution to your problem,just be sure to use PT sleepers.
12-29-2012, 05:54 PM
#15
Last question and then that's it (until the next time  ): Should I anchor the sleepers to the concrete? If so, with what? Thanks again all. -Aaron
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
