New Concrete Over Old Concrete Pier - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-05-2016, 11:33 AM   #1
Rewards Points: 124
I've started rebuilding the foundation of my shed. I just discovered that I have concrete piers (likely 4' deep cause we're have freeze here). The picture shows the concrete pier from the side, because I have not moved the shed off the existing foundation yet.
However, since those concrete piers were poured decades ago, the yard has been re-graded, so now some of those poured concrete piers are below grade by as much as 3".
I am planning to add new concrete to the top of the concrete piers that are too low, to bring them higher, because attaching my new shed base (PT wood) to a concrete pier that is below grade is only asking for future rot.
BUT, the surfaces of the existing piers are not flat (so I can't just drop a concrete block on the top). The round formed concrete (3" high) protrudes from the footing, and then there is a metal post anchor (4" high) in the top of that. So I would have to add at least 7" of new concrete.
Can I just place a form, add concrete adhesive according to directions, and throw in the 7" of new concrete and a new post anchor? Or is there something else I need to consider?
Thanks for your help.
succeed is offline   Reply With Quote
Old 09-05-2016, 03:05 PM   #2
Rewards Points: 3,748
Re: New Concrete Over Old Concrete Pier
Sounds like a plan, just be sure you clean the tops of the existing piers well, before you add the bonding agent.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
succeed (09-05-2016)
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 08:58 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
Do I need a form for the concrete pier or just fill up the hole I dug? graysqwrl Building & Construction 1 07-20-2011 07:44 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
