New Concrete Much Dark Than The Old - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-28-2012, 10:40 AM   #1
jeh
jeh's Avatar
New concrete much dark than the old
when t
jeh is offline   Reply With Quote
Old 03-28-2012, 10:45 AM   #2
Rewards Points: 13,300
New and old will always look differant. As far as the finish, all depends on how it was done. There's at least 3 differant ways they could have finished it.
Without being there or at least a picture the concrete guys on here would be just guessing when try to make suggestions.
Old 03-28-2012, 11:17 AM   #3
jeh
jeh's Avatar
ok, tha
Old 03-28-2012, 01:27 PM   #4
joed's Avatar
Rewards Points: 12,012
The concrete looks brand new. Wait for it to cure and dry out more. Wait at least 28 days and see what it look like then.
Old 03-28-2012, 02:42 PM   #5
jeh
jeh's Avatar
will it have the same look of having stones in it and turn the same color?
Old 03-28-2012, 02:47 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Let it fully cure (as stated). The color will lighten up.
Its not going to be the same "exact" color and detail-finish .... as the old, worn, aged, exposed and walked-on concrete.
I think your expectations are not very realistic.
Example: http://www.ehow.com/how_8684754_dark...match-old.html
....not every company uses the same formula, or even the same ingredients. Even contractors in the same area may use different brands. Because of this, new or replacement cement will almost certainly not initially match the tone of the older cement. There are some ways to artificially age and darken new cement, but matching 100 percent is difficult....
FWIW - I have a standard clause in all my contracts that state that same point, for a variety of finish materials (No way to guarantee that new - will exactly match old. In somer instances, the only way to match is to go all new). This helps to manage expectations.
- Build Well -
Old 03-28-2012, 02:51 PM   #7
jeh
jeh's Avatar
ok, so what can i do to help blend it a little better in the interim? I have heard muriatic acid can help weather it but don't know if this would change the color?
Old 03-28-2012, 04:43 PM   #8
Rewards Points: 1,232
Also, if you make the patch match the old while it is fresh, then it will no longer match when it ages.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
concretemasonry (03-28-2012)
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
