New Concrete Garage Floor Cuts W Chipping - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-05-2012, 07:35 PM   #1
new concrete garage floor cuts w chipping
Newly poured concrete gargage floor 2 days ago was cut today by contractor. Cuts are a not as "clean" as i would expect. Cut edges have chips here and there along the edges. Should i be concered about the strength of the concrete? WOuld a dull blade contribute to this?
pmay is offline   Reply With Quote
Old 11-05-2012, 08:18 PM   #2
firehawkmph's Avatar
Rewards Points: 1,936
I wouldn't worry about it. When they are cutting, just a slight movement side to side can cause a chip. The concrete is still a long way from hardening when it's that fresh. The chips I am talking about are very small. If you are getting big chips that are noticeable without looking too hard, then that's a different story. That would fall under sloppy workmanship.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 11-07-2012, 12:11 AM   #3
Mike Hawkins
Mike, thanks for your reply. Here's a pic of garage floor cut. What do you think?
Old 11-07-2012, 07:57 AM   #4
Those are a little bigger than they should be. But what's done is done. I wouldn't worry about it.
Mike Hawkins
Old 11-07-2012, 08:31 AM   #5
concretemasonry's Avatar
Rewards Points: 2,654
Probably cut too late. I should be cut as soon as you can get access and no more than 24 hours after pouring.
Possibly the wrong type of blade.
Dick
concretemasonry is online now   Reply With Quote
Old 11-09-2012, 03:27 PM   #6
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
I wouldn't be too concerned about the strength of the concrete. Of course, I say that without seeing how it was poured, but that chip isn't really an indicator one way other the other.
Mort is offline   Reply With Quote
Old 11-10-2012, 11:24 AM   #7
Rewards Points: 1,232
Cut too late, no issues other than cosmetic.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-11-2012, 09:32 PM   #8
Mike Hawkins
Thanks for the feedback
Old 11-11-2012, 09:35 PM   #9
The concrete was poured when temps were flirting with freezing so they added calcium to the pour. Cutting took place about 4 days after the pour. Thanks for your feed back.
Old 11-11-2012, 09:37 PM   #10
Thanks for the feedback. It seemed like they waited longer than normal to come back to cut which was 4 days after pour.
Old 11-12-2012, 10:40 AM   #11
Mort's Avatar
Rewards Points: 694
Was it calcium or a non-CC accelerator? If it was calcium, is there steel in the slab, either rebar or wire mesh? If so, keep an eye on it, calcium corrodes the steel at an accelerated rate. This could cause strength problems, and I've even seen the rust color show itself in walls and slabs.
Adding an accelerator is fine, as long as its used properly.
How to repair Concrete chipping outside of house T_MB General DIY Discussions 7 05-11-2011 05:47 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 08:23 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
