New Concrete Driveway Stained - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-22-2012, 11:27 AM   #1
New concrete driveway stained
So our home is new and the front concrete driveway was poured in December. They placed tarps over it to keep it from freezing and when they removed it there were designs stained into the concrete wherever the tarp had touched the drying concrete. Months later the ugly designs are still there. Is there a way to remove these stains?
crumb is offline   Reply With Quote
Old 02-22-2012, 11:49 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,... Give it time, 'n it'll wear off...
Old 02-22-2012, 01:07 PM   #3
Here is a picture of it:
Old 02-22-2012, 04:39 PM   #4
How much time is something like this supposed to take? It has been a couple months. Are we talking a year?
Old 02-22-2012, 04:43 PM   #5
Bondo's Avatar
Ayuh,.... Possibly, or less....
it took 28 days to cure....
Old 02-22-2012, 05:54 PM   #6
Rewards Points: 4,792
if its any consolation, most hgwys have the same trouble in areas,,, it will wear off as tires abrade the paste,,, we had the same problem last year - rain came in,,, we went back & pressure washed the paste which opened the surface & removed the stains,,, h/o was happy but i wouldn't have done it on my own d/w
stadry is online now   Reply With Quote
Old 02-22-2012, 08:55 PM   #7
Rewards Points: 79
Second the pressure washing. This exact kind of thing happened to my neighbor, although it was more the result of a sloppy concrete coloring job. Two years later it is just now starting to weather off. I was pressure washing my driveway over the summer and noticed it can actually take off a thin layer of concrete if you use a 10-degree hoze nozzle, which should help the problem.
juryduty is offline   Reply With Quote
Old 02-22-2012, 09:11 PM   #8
that ' thin layer ' of concrete is actually the paste ( cream ) that's brought to the top by finish troweling,,, we prefer using a turbo nozzle - its faster & easier to blend the resultant surface 10* is touchy for many to use
Old 02-24-2012, 09:55 PM   #9
analogmusicman's Avatar
Rewards Points: 560
don't know. I had a concrete driveway poured 7 years ago, the tarps that were put on seem to have stained it and the stains are still there. of course,the contractor was gone right after he got his money.
tnx,
analogmusicman is offline   Reply With Quote
Old 02-25-2012, 05:02 PM   #10
Some of the white staining you are seeing is efflorescence. This is basically dried salts (calcium carbonate) that naturally rises up through the concrete along with moisture vapor. Since none of the moisture was allowed to evaporate into the air, any salts or minerals the moisture carried to the surface was deposited on the surface of the concrete.
Some of the darker areas are from the wrinkles in the tarps not allowing the concrete surface to cure evenly. The different rate of evaporation between the part of the tarps that laid flat on the concrete and the parts that were wrinkled causes this. These can take a year of two to fade.
Pressure washing and scrubbing the surface will help remove the efflorescence and should fade the effect you are seeing now. I would prepare to live with this for a while though. If you feel, after a year, the blotchy-ness hasn't subsided, you could acid-stain the concrete which would give the concrete some color and a mottled look, then apply a good concrete sealer. I know this isn't what you had in mind, but is a possible solution to hide the shadowing you see now.
Creteexpert is offline   Reply With Quote
Old 02-26-2012, 12:09 PM   #11
Concrete & Masonry
Rewards Points: 636
I agree with the others that it will take a long time for the stains to completely disappear. I use poly "Visqeen" as the last resort when covering concrete, and pull it off as soon as possibly, as this is fairly common when covering concrete with plastic, especially when the concrete has chloride-based accelerant.
jomama45 is online now   Reply With Quote
New Construction Questions Stained Concrete and Windows smith83695 Building & Construction 8 03-28-2011 12:55 PM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 03:42 PM
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 08:07 AM
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 09:24 AM
How do I get bids for Concrete Driveway? SkyCloud Building & Construction 2 07-19-2008 03:07 AM
