Nervous About Concrete In Post Holes - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-18-2012, 06:48 PM   #16
Registered User
Rewards Points: 4,894
Gravel is better to disperse any water around the post, concrete (sponge) will keep the water at the post. As the post section above ground dries, the stored water capillary wicks up - saturating until dry.http://www.sustland.umn.edu/implemen..._footings.html
For those with a deep frost-line, put more post below the frost-line; for the soil to counter the ice-lenses upward pressure; http://www.brainerdhomeinspection.com/frosth~1.pdf
Alkalinity in concrete may help rot the wood (need further research), treat the wood a year later; http://www.ehow.com/info_8535764_woo...-bad-idea.html
If you go concrete, keep it 6" below grade, water-proof post at concrete, termites; http://learningstore.uwex.edu/assets/pdfs/A3052.pdf
Cedar life-time; with/out concrete; http://www.bydfence.com/fqa.htm Taken with a grain of salt...
Gary
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Proper methods to fill concrete gaps, holes, cracks and resurface concrete jzam42 Building & Construction 6 07-21-2010 12:50 PM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 11:50 AM
