Need A Weight Bearing Front Porch - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-18-2014, 04:47 PM   #1
"I Got This" Man
Rewards Points: 16
Need a Weight Bearing Front Porch
I have a front porch that needs built that supports two beams for my overhang. The idiot that I bought the house from had the beams sitting on an extremely poorly done paver job and the overhang is starting to sag. I would like to do it myself so I can learn in the process but have no clue as to the specifics.
The dimension will be 6 x 8 and I live in Austin, AR (no frostline issues that I know of). Basically, if anyone can point me in the right direction with info from start to finish, or a resource that I can access to read up on concrete work, it would be greatly appreciated. If this sounds like a big job best suited for a contractor please feel free to point that out as well. However, there is nothing that I won't try to do myself if it is possible to do so. I can upload pics as well if it helps.
F150MSGT is offline   Reply With Quote
Old 06-18-2014, 04:56 PM   #2
Rewards Points: 14,278
Without pictures no one can do anything but guess.
"I have a front porch that needs built that supports two beams for my overhang"
Not even sure what that means.
Any supports needed to be sitting on footings, not just on patio blocks.
Old 06-18-2014, 08:55 PM   #3
Rewards Points: 6,652
Find out what your local codes are, regarding Decks and porches. They may require a buried footing where the columns will attach to the decking. Also most likely will require two sistered 2x8's or 2x10's at where the columns are.
Lowe's and Home Depot have deck & porch design kiosks. Just draw one up, and take to your county or city code office to get them to sign off on your plan. They will also tell you about footing depth, etc..
Old 08-16-2014, 02:45 PM   #4
"I Got This" Man
Rewards Points: 16
Thank you for the advice. Sorry so late to the response also. I got a last minute tasking and had to jet out of town....military life I will check with the code folks and get the skinny. Thank you again.
Old 08-18-2014, 08:26 AM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
Take a picture of what you have now, so we can better advise what you need to do.
I hate signatures.
Mort is offline   Reply With Quote
Front Porch Renovation ashton44 Building & Construction 4 03-09-2014 01:49 PM
Please help with concrete front porch and step mdambrosio Building & Construction 6 05-26-2011 07:48 AM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
Front porch shed roof addition GIDGEEGIRL1 Building & Construction 0 10-28-2010 12:16 AM
New Circuit to outside front porch - need help Leah Frances Electrical 12 05-13-2010 03:12 PM
