Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-16-2012, 06:27 PM   #1
Need waterproof advice/outdoor fountains
I have two brick planters on each side of my front steps (2' tall, 3' X 2.5'). Basically brick walls boxes on a concrete slab attached to my front porch. They were smoothed out with mortar and I used a rubber paint to waterproof so I could put fountains and fish in. It was too much of a job each year ripping off the rubber and repainting. I have removed the rubber and the mortar mix. Wanted to tile the inside with glass tile and use for fountains only.
I have removed the mortar and was planning on putting in concrete board, using the special bond quickset for water/outdoors and epoxy grout. I fear that the water will seep through the brick though. Any correct solutions would be greatly appreciated.
Need waterproof advice/outdoor fountains-045.jpg   Need waterproof advice/outdoor fountains-043.jpg   Need waterproof advice/outdoor fountains-046.jpg
Cathieisgood is offline   Reply With Quote
Waterproof Flooring (that isn't tile) shadetree Flooring 1 12-17-2011 06:54 AM
Want to waterproof foundation around cool room humberguy General Discussion 2 04-04-2010 07:21 PM
Do I need to waterproof my basement if I already have a french drain? buratti Building & Construction 4 03-20-2010 04:32 PM
What should I use as a waterproof membrane for an outdoor tile project? CliffQ Flooring 3 05-18-2008 03:52 PM
waterproof plaster shower walls carsokk Remodeling 2 01-31-2008 09:14 AM
