Need Help Fireplace Hearth Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-07-2017, 02:09 PM   #1
Need help fireplace hearth slab
Not sure what type of material I am dealing with here. But we have a stone e fireplace with a slab out front of the firebox. Apparently sometime before we bought the home someone had some burning logs rolled out and it burned scorched the top of the slab. I tried some masonary fireplace cleaner last night with a scotchbrite pad and it lightened it up but it's still there and the slab where I did this is a little discolored now. I'm not sure what I have here though....Limestone, Sandstone, or concrete? I just went out and bought a 5" Random orbital sander to perhaps try sanding it. I don't know what grit sandpaper to buy or nothing.Then I would think it needs to be sealed also. It looks like it was sealed at one other time. You can see a layer of something good on the top surface. I've added 3 photos. The last one is after I used that cleaner last night and it discolored. Any help would be much appreciated.
Need help fireplace hearth slab-20170105_230459_1483819662822.jpg   Need help fireplace hearth slab-20170105_185548_1483819693900.jpg   Need help fireplace hearth slab-20170107_114940_1483819722764.jpg
Steves6354 is offline   Reply With Quote
Old 01-07-2017, 02:44 PM   #2
Rewards Points: 430
Re: Need help fireplace hearth slab
I'm guessing that it is sandstone, which is relatively soft and porous. Try warm water and dawn dish so first with a scrub brush, if it is no go, move on to a weak tsp solution. Ron
ront02769 is offline   Reply With Quote
Old 01-07-2017, 02:46 PM   #3
What is tsp solution stand for?
Old 01-07-2017, 07:19 PM   #4
Well after the above didn't work. I decided to start sanding. It actually looks 100's better now and I just started with some 80grit. So plan is to do the whole slab with 80 up to 120 and then wipe it down with some water. Let it dry and seal it. What do I need to buy for sealer for Sandstone? Is there a a specific place, product that I should buy or one that someone has worked?
Old 01-08-2017, 10:42 AM   #5
Rewards Points: 3,610
Trisodium Phosphate
Canarywood1 is offline   Reply With Quote
Old 01-08-2017, 10:50 AM   #6
Rewards Points: 2,016
For a sealer try Quikrete Concrete Sealer,
It should work fine.
ED
de-nagorg is online now   Reply With Quote
Old 01-08-2017, 02:52 PM   #7
Rewards Points: 4,638
think i'd choose a mat finish epoxy over any sealer
Old 01-09-2017, 05:44 PM   #8
Concrete & Masonry
Rewards Points: 568
That certainly looks like Indiana Bedord, which is a very common (and relatively soft) stone. I was going to suggest using an orbital sander (or belt first, if it was really bad), but you already figured it out. Sanding them has gotten us out of a lot of tight spots in the past.
jomama45 is online now   Reply With Quote
Old 01-10-2017, 06:49 AM   #9
jo', is your ' Indiana Bedord ' what we called ' Amhearst ' ???
no world of conc this year for you ? ? ? me either - every other year's fine
Old 01-24-2017, 11:58 PM   #10
Rewards Points: 132
tsp solution stand for? "Trisodium Phosphate"
Trisodium Phosphate is a strong chemical typically used as a cleaning agent, food additive, stain remover and degreaser.
harrisong35 is offline   Reply With Quote
Stone Fireplace Hearth sharingsunshine Concrete, Stone & Masonry 13 07-27-2013 01:46 PM
Replacing fireplace hearth material knacrelli Tiling, ceramics, marble 0 07-24-2013 10:19 AM
Micore board on concrete slab floor before granite hearth? BlueBSH Flooring 3 01-19-2013 12:32 PM
Installing a tile fireplace hearth mlheath Concrete, Stone & Masonry 7 11-04-2012 09:50 AM
Fireplace hearth dilemma musa1227 Tiling, ceramics, marble 3 10-17-2011 08:22 PM
