Need Advice/opinions On Leaky Poured Concrete Foundation Crack Please (it's A Novel) - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-20-2013, 10:20 AM   #16
Originally Posted by itsreallyconc
we typically inject from INSIDE the wall by drilling holes at an angle that intersects the crack halfway inside the wall,,, we then vac out the dust, insert 3/8" bang ports, screw in grease fittings, & inject mtl thru those w/2part gun - e side's wtr & the other's polygrout,,, we butter the crk w/hydraulic to prevent spillage & direct the mtl to where we want it to go
Emecole explained to me that the method you're describing is meant for 2 part products (like you use), but not necessary for 1 part products like theirs. Thus, the product can be injected directly onto/into the crack. Once it touches moisture, it'll expand up to 30 times its size, reaching all crevices and to the outside of the crack. This expansion is why they also instruct to "butter" the crack. This forces the expansion to move outward.
Seem reasonable?
Wes8398 is offline   Reply With Quote
Old 04-20-2013, 01:56 PM   #17
Rewards Points: 4,656
we inject 1 part like theirs & fill the other side w/wtr but that's the experience talking a bit,,, after using trailer loads of the stuff, we shouldda learnt sumthin', right ?
Old 04-20-2013, 02:16 PM   #18
lol Well, I appreciate you taking the time to help me out. This whole trench thing workin' out as a drainage method really makes me a lot more comfortable with trying to seal this crack myself. As I said earlier, even if its not 100% successful, I don't think ill be getting water on my floor again anyway...
Old 04-22-2013, 02:24 AM   #19
if its not 100% successful, you probably will,,, grouting is as much art as science,,, just remember wtr runs downhill & your bsmt's as a ship's hull below the wtrline
hopefully we'll never talk about this again - good luck ! ! !
Old 04-22-2013, 09:53 AM   #20
Sorry...probably will what? I wasn't saying water wouldn't come in anymore. Just meant the water won't be on the TOP of the floor, wrecking my laminate again.
Again, thanks a lot for the help.
Foundation crack on old milk barn. How to fix?? esblair Concrete, Stone & Masonry 2 02-20-2012 12:34 PM
home-made ThermoMass concrete poured wall? jklingel Building & Construction 16 12-09-2010 08:06 PM
Crack in foundation? cbzdel Building & Construction 6 09-02-2010 09:12 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
Crack in Concrete Slab under the Front Door diy4life Building & Construction 4 04-08-2009 09:11 AM
