Need Advice For 2 Footings - Concrete, Stone & Masonry - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-24-2012, 06:43 PM   #31
Rewards Points: 93
Thank you Daniel. I was mearly trying to fill in the blanks that hes not required to fill. Im not a pro and that is why i rather research the hell out of something before doing it so it can be done correct.
Originally Posted by Daniel Holzman View Post
I don't follow why folks are getting so bent over this thread. There seems to be a perfectly good engineering plan for a footing. There is a plan for a steel beam. The engineer quite correctly did not specify means, methods, techniques or sequences of construction, that is NOT their job. They specified a minimum strength of concrete, a minimum footer size. Perhaps they could have specified the exact method of attaching the column to the floor, sometimes it is done, sometimes that is left to the detailer or the contractor.
The project seems pretty solid to me. There is absolutely no need to tie the slab into the footer, it accomplishes nothing, and is rarely done even in commercial construction. The slab simply is there to provide a flat walking surface it has not structural significance, while the footer supports the column. Due to the slight potential for differential movement between the slab and the footer, it is common practice in commerical installations to install a flexible joint between the column footer and the slab, however if you install the footer below the surface of the slab, then add the floor slab later to make a flat floor, you may want to install a slip surface over the footer (grease or similar) to minimize the potential for cracking the slab. In a basement installation, this is a minimum concern problem, more of an issue where the slab can get warm while the footer remains cold.
Good luck with the project.
simonb is offline   Reply With Quote
Old 06-24-2012, 09:42 PM   #32
Rewards Points: 3,426
Originally Posted by simonb View Post
Spoke to my engineer again this afternoon and he said the same. The size of it I can really screw it up fast using a vibrator. He said to poke at it with a stick to make sure it gets all over.
That's why i said in the beginning of this post,you don't need a vibrator,but you insisted on one.
Canarywood1 is online now   Reply With Quote
Old 06-24-2012, 09:53 PM   #33
Rewards Points: 93
Well the guy at the concrete place told me i would screw it up if I didnt use a vibrator. So i was kindof putting my faith in the guy.
Old 06-25-2012, 03:09 PM   #34
Old School
Willie T's Avatar
Some advice?
Take some time to actually go to jobs and watch concrete being placed. Ask some of the OLDER workers who have obviously been doing this for a while why they do (or DON'T do) what they are doing.
Willie T
Old 06-25-2012, 07:42 PM   #35
Concrete & Masonry
Rewards Points: 530
One more person here telling you to skip the vibrator for the footings..........
They're simply too small to require vibration, and the density of the concrete is far from being the weak point in the entire equation.
For future reference though, running a vibrator is relatively simply IF you remember the rate at which to vibrate: Let the head sink into the the concrete at it's own pace and extract it from the concrete at an equal, or even slower rate. It's important to remove it from the concrete slowly, as the void needs to fill behind the head........
jomama45 is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 09:40 AM
Advice on Retrofit Water Drainage For Foundation 4 FT Under cloves Building & Construction 13 04-07-2010 11:47 PM
footings vs pylons smarbaga Building & Construction 1 03-26-2008 10:53 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
