Nail Holes In Cinder Block Chimney - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-22-2012, 05:20 PM   #1
Rewards Points: 152
Nail holes in cinder block chimney
Took the siding off my chimney today to try to stop the bats from roosting.
Pulled some masonry nails out at the same time, left a bunch of holes. Unfortunately, some of them are about 35' above the ground :|
Do I need to get some mortar or something to fill them in (wasn't sure if water would get into them, then freeze/thaw, etc) or? If so, what should I use?
burnt03 is offline   Reply With Quote
Old 10-22-2012, 09:45 PM   #2
Rewards Points: 222
repair mortar in a mortar bag will make quick work of that.
Fix'n it is offline   Reply With Quote
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 11:22 PM
Removing White Powdery Substance From Cinder Block Lawrence Coppar Concrete, Stone & Masonry 5 04-12-2012 03:28 PM
Wire through cinder block Red Squirrel Electrical 9 07-04-2010 05:45 PM
building concrete steps cinder block frame? drewhart Building & Construction 2 06-10-2010 02:48 PM
patching holes in basement cement block wall jhiner Building & Construction 3 06-02-2010 04:03 PM
