My Garage Wall Bricks Seems To Be Cracking Where The Brick Wall Contacts - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-05-2012, 02:08 PM   #1
My garage wall bricks seems to be cracking where the brick wall contacts
My garage wall bricks seems to be cracking where the brick wall contacts the concrete slab. Also the concrete driveway & walk seem to be pulling away from the garage wall. I'm would like to know what has caused this issue & what I should do to fix it.
You can see 5 pictures at the link below. The first 2 are the right wall when facing this garage (this garage is attached to the house).
The next 3 are the left wall.
The garage & house are in Michigan.
The pictures are here:
http://www.flickr.com/photos/55999039@N04/
Thanks In Advance,
Uni
Unicornz0 is offline   Reply With Quote
Old 09-05-2012, 08:35 PM   #2
Rewards Points: 3,426
Happens all the time,more than likely settling issues.
Canarywood1 is offline   Reply With Quote
Old 09-05-2012, 10:31 PM   #3
Concrete & Masonry
Rewards Points: 536
The brick is taking on unnecessary water, freezign in winter, and the brick are spalling. Replace the concrete that has settled and you will fix the cause......
jomama45 is offline   Reply With Quote
Replacing garage door with wall containing window and/or door diyer101 Remodeling 9 11-23-2012 08:47 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Garage CMU partial wall - shifted block ChrisJJ Building & Construction 9 04-01-2011 01:27 PM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 08:41 PM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 06:57 AM
