My Chimney Damper Is Stuck Open And I've Got No Chimney Cap... - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-09-2013, 01:22 PM   #1
Rewards Points: 379
My chimney damper is stuck open and I've got no chimney cap...
I'm concerned about rain, birds, critters, snakes, etc...getting in my house through my chimney flue & vents. The flue is 13inchx13inch and the other 2 vents are basically a concrete block on it's side being used to vent nothing & I'm planning to close them in.
I'm not finding many with experience on chimneys/fireplaces in this area but one co. I called told me that I could not put a cap on it because the flue and vent openings are flush with the chimney top. Also the chimney top is flat but should be pitched away from openings.
I was told that if I want to put a cap, a full size chase cover will not work because that assumes you have a working damper. So, I'd have to chip away some of the concrete around the flue and add enough additional flue/vent to rise above the chimney top to be able to attach a cap...then I need to build up and pitch the chimney top away from the new higher flue/vents.
Your thoughts and opinions are greatly appreciated.
I'd also like to re-stucco the chimney to a more smooth finish rather than the brick look. That said, which should be done first...?
A) Adding a short section of tile flue and concrete crown.
B) Re-stucco brick finish to a smoother finish.
Thanks!
a1481155 is offline   Reply With Quote
Old 05-09-2013, 03:10 PM   #2
Amateuralex's Avatar
Rewards Points: 270
I put chimney caps on at my house just last week. The model from lowes will work in a chimney like yours, but you have to order an additional kit of legs that sit down in the flue.
Amateuralex is offline   Reply With Quote
Old 05-09-2013, 05:26 PM   #3
Concrete & Masonry
Rewards Points: 470
Not sure about where you're at, but here the flue must extend at least 4" above the cap/crown. I don't care for the way the cap is either, but it's likely you don't see the freeze-thaw cycles where you are like we experience. A cap should really be concrete, and have at least 2" overhang overhang over the brick, with a drip edge in the underside. As for the damper, do a search for "chimney top dampers"..............
jomama45 is offline   Reply With Quote
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
a1481155 (05-11-2013)
Old 05-11-2013, 12:37 AM   #4
Rewards Points: 379
Introducing my new best friend;
PB Penetrating Catalyst.
Sorry I didn't post before pics but after 2 rounds of WD-40 & wire brush, I found this stuff on sale at HD and ended up using the entire can in several stages today.
I have 3 hinges on my damper & handle; I basically smothered the 2 top hinges on each side especially the middle one, let them soak for a while, then aggressively scraped the hinges with the wire brush, then forcefully tried to pry the damper handle open & closed manually.
..repeated...repeated...
...repeated...repeated...
Let me say, I probably was not forceful enough when I first tried to pry open the damper after the first 2 rounds with the WD-40 but since I had the inspector tell me not to worry about breaking anything, I started all over again...
I smothered the 2 top hinges on each side, let it soak for a while, then hit the hinges with the wire brush then aggressively try to pry the damper handle open & closed.
POP!
That did it; this Beatch is closed!
So now my options change...
I can go for a chase cover and/or just cap...am I missing any other options?
Old 05-11-2013, 08:21 AM   #5
Rewards Points: 12,882
Someones still going to have to finish off the crown on that chimmney.
It's complety wrong the way it is now.
With now it's forming a pond for water to just run down inside the flue.
Should have looked like this.
http://www.bing.com/images/search?q=...ectedIndex=148
Old 05-11-2013, 09:19 AM   #6
Rewards Points: 379
Thanks! I'd also like to re-stucco the chimney to a more smooth finish rather than the brick look. That said, which should be done first...?
Old 05-11-2013, 09:48 PM   #7
Dave Sal's Avatar
Rewards Points: 576
Functionality always trumps cosmetics. Get it working properly and capped to prevent water issues, then you can deal with how it looks.
Dave Sal is offline   Reply With Quote
Old 05-12-2013, 03:13 PM   #8
Rewards Points: 379
Good point, thanks!
Old 05-12-2013, 03:33 PM   #9
Rewards Points: 379
How about if I go with something like this chase cover with a single flue cap in stainless steel or copper?
Old 05-12-2013, 09:27 PM   #10
Concrete & Masonry
Rewards Points: 470
That will work, but I'd still plan on making it bigger than the existing brick chase, so that there's some overhang and a drip-edge, especially if you plan on stucco on the chimney........
Old 05-13-2013, 12:46 PM   #11
Rewards Points: 379
Thanks! How does this sound? The stucco guy says he can build it up a little with concrete to give me a small pitch all around the flue, cover the 2 smaller holes that I don't need and give me a bit of an edge.
