-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   My chimney damper is stuck open and I've got no chimney cap... (http://www.diychatroom.com/f105/my-chimney-damper-stuck-open-ive-got-no-chimney-cap-179154/)
a1481155 05-09-2013 12:22 PM
I'm concerned about rain, birds, critters, snakes, etc...getting in my house through my chimney flue & vents. The flue is 13inchx13inch and the other 2 vents are basically a concrete block on it's side being used to vent nothing & I'm planning to close them in.
I'm not finding many with experience on chimneys/fireplaces in this area but one co. I called told me that I could not put a cap on it because the flue and vent openings are flush with the chimney top. Also the chimney top is flat but should be pitched away from openings.
I was told that if I want to put a cap, a full size chase cover will not work because that assumes you have a working damper. So, I'd have to chip away some of the concrete around the flue and add enough additional flue/vent to rise above the chimney top to be able to attach a cap...then I need to build up and pitch the chimney top away from the new higher flue/vents.
Your thoughts and opinions are greatly appreciated.
I'd also like to re-stucco the chimney to a more smooth finish rather than the brick look. That said, which should be done first...?
A) Adding a short section of tile flue and concrete crown.
B) Re-stucco brick finish to a smoother finish.
Thanks!
http://imageshack.us/a/img195/1018/chimneytop.jpg
Amateuralex 05-09-2013 02:10 PM
1 Attachment(s)
I put chimney caps on at my house just last week. The model from lowes will work in a chimney like yours, but you have to order an additional kit of legs that sit down in the flue.
jomama45 05-09-2013 04:26 PM
Not sure about where you're at, but here the flue must extend at least 4" above the cap/crown. I don't care for the way the cap is either, but it's likely you don't see the freeze-thaw cycles where you are like we experience. A cap should really be concrete, and have at least 2" overhang overhang over the brick, with a drip edge in the underside. As for the damper, do a search for "chimney top dampers"..............
a1481155 05-10-2013 11:37 PM
Introducing my new best friend;
PB Penetrating Catalyst.
http://imageshack.us/a/img248/9611/dsc00442hg.jpg
Sorry I didn't post before pics but after 2 rounds of WD-40 & wire brush, I found this stuff on sale at HD and ended up using the entire can in several stages today.
I have 3 hinges on my damper & handle; I basically smothered the 2 top hinges on each side especially the middle one, let them soak for a while, then aggressively scraped the hinges with the wire brush, then forcefully tried to pry the damper handle open & closed manually.
..repeated...repeated...
...repeated...repeated...
Let me say, I probably was not forceful enough when I first tried to pry open the damper after the first 2 rounds with the WD-40 but since I had the inspector tell me not to worry about breaking anything, I started all over again...
I smothered the 2 top hinges on each side, let it soak for a while, then hit the hinges with the wire brush then aggressively try to pry the damper handle open & closed.
POP!
That did it; this Beatch is closed!
So now my options change...
I can go for a chase cover and/or just cap...am I missing any other options?
http://imageshack.us/a/img40/9213/dsc00402b.JPG
http://imageshack.us/a/img209/3008/dsc00412at.jpg
joecaption 05-11-2013 07:21 AM
Someones still going to have to finish off the crown on that chimmney.
It's complety wrong the way it is now.
With now it's forming a pond for water to just run down inside the flue.
Should have looked like this.
http://www.bing.com/images/search?q=...ectedIndex=148
a1481155 05-11-2013 08:19 AM
Thanks! I'd also like to re-stucco the chimney to a more smooth finish rather than the brick look. That said, which should be done first...?
Dave Sal 05-11-2013 08:48 PM
Functionality always trumps cosmetics. Get it working properly and capped to prevent water issues, then you can deal with how it looks.
a1481155 05-12-2013 02:13 PM
Good point, thanks!
a1481155 05-12-2013 02:33 PM
How about if I go with something like this chase cover with a single flue cap in stainless steel or copper?
http://imageshack.us/a/img24/3345/ch...coverparts.jpg
jomama45 05-12-2013 08:27 PM
That will work, but I'd still plan on making it bigger than the existing brick chase, so that there's some overhang and a drip-edge, especially if you plan on stucco on the chimney........
a1481155 05-13-2013 11:46 AM
Thanks! How does this sound? The stucco guy says he can build it up a little with concrete to give me a small pitch all around the flue, cover the 2 smaller holes that I don't need and give me a bit of an edge.
