Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-27-2012, 12:33 PM   #1
My brick foundation has been parged... on the inside
I have a brick foundation on a hundred year old house in Denver. Soft brick, lime mortar. At some point, I'm guessing the 50's from a paper I found stuffing a hole, the foundation was parged below grade on the inside with what must be portland cement, because its really hard.
I've read through the forums, and have learned of the problems with this "waterproofing" technique. So on the one hand, it sounds like the parging should be removed, as it is preventing the brick from breathing, ruining the brick, and its likely delaminate and fail anyway.
On the other hand, I have a lot of other stuff to do, and a strong believer of "if it aint broke, don't fix it". The parging looks fantastic. Its solid, not crumbling, and shows no signs of water leakage. I chipped off about a square foot to see if the brick underneath was rotten, but it looked solid, and the mortar too. And I learned the parging is REALLY hard to get off without damaging the brick. It is still stuck really well to the brick.
So what to do? Denver is pretty dry, is there any chance that this out-dated waterproofing technique is actually working OK? Its lasted ~60 years. Or am I just avoiding work? (And to be fair, I don't really know if I can even get the parging off without damaging a lot of brick.)
denvercraftsman is offline   Reply With Quote
Old 08-27-2012, 12:38 PM   #2
I'd leave it alone.
concretemasonry (08-27-2012)
Old 08-27-2012, 01:22 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Leave it alone. Parging was used to help create a finished look, both inside and outside on foundation walls. You can take the handle end of a screw driver and tap along to make sure it is solid and not loose.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
The Following User Says Thank You to gregzoll For This Useful Post:
Tags
brick, foundation, lime, parging, portland
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 03:22 PM
Replacing brick foundation wall bigdog54 Building & Construction 1 12-02-2010 06:41 AM
Adding brick ledge to foundation ecb3 Building & Construction 10 12-01-2010 10:08 PM
Reusing old brick for a shop bigalpha Building & Construction 12 01-20-2010 08:59 PM
Old Brick House inside walls rick32 Building & Construction 6 11-08-2007 07:49 PM
