Muratic Acid - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-14-2014, 07:17 PM   #1
Rewards Points: 151
Muratic Acid
A few years back, I bought a few gallons of muratic acid to clean a new brick wall. I had about a gallon and 1/2 let over and stored it in my shop on some gorilla rack shelving. I'm sure you brick guys know the consequences of that...rust! I'll likely find a mason to give the acid to, but what about the shelves? Will the rust spread? Should I remove the section of shelves that started rusting or is it not an issue. Thanks! Bob
Bob... is offline   Reply With Quote
Old 03-14-2014, 10:38 PM   #2
Rewards Points: 13,300
Going keep on eating until there's noting left to eat.
Neutralize with a Baking Soda and water paste.
Rinse off with water, let dry, spray on some rust inhibitor then paint.
http://www.amazon.com/Rust-Oleum-224284-Stops-Inhibitor-10-25-Ounce/dp/B002BWORQS
Bob... (03-14-2014)
Old 03-14-2014, 10:47 PM   #3
Rewards Points: 151
http://www.amazon.com/Rust-Oleum-224.../dp/B002BWORQS
Exactly what I needed to know. Thx Joe.
Old 03-15-2014, 04:49 AM   #4
Rewards Points: 4,534
ammonia will also neutralize acid,,, typically we etch w/apron/vest store 1 HCl : 8 water,,, after the fizz stops, we neutralize w/ 1 Amm : 8 wtr
Old 03-17-2014, 02:01 AM   #5
Rewards Points: 151
Hi itsreallyconc. So 1 part ammonia to 8 parts water? Could that be sprayed with a pump spray bottle? Would it have to be rinsed (or pump spray also). I'm actually looking for a quick way to neutralize it without having to pull the shelves to rinse outside (I just found out that I'll be very short on time for the next few weeks).
Old 03-17-2014, 03:24 AM   #6
we use a garden sprinkle can but i suppose it could be spritz'd,,, if you're short on time, just sprinkle w/baking soda & get to it next week.
The Following User Says Thank You to stadry For This Useful Post:
Bob... (03-17-2014)
Old 03-17-2014, 08:31 AM   #7
landfillwizard's Avatar
Rewards Points: 502
Make sure you get a respirator with the proper filters before you spray any acid or base! Several chemical reaction may occur that could produce a hazardous gas!
landfillwizard is offline   Reply With Quote
The Following User Says Thank You to landfillwizard For This Useful Post:
Bob... (03-17-2014)
Old 03-17-2014, 08:41 AM   #8
Rewards Points: 1,268
ditto
de-nagorg is online now   Reply With Quote
Old 03-17-2014, 10:55 AM   #9
Rewards Points: 151
Thanks for the help!
Replacing water-based concrete stain with acid? juliesad Concrete, Stone & Masonry 4 08-24-2013 06:59 PM
Bathroom cleaning tip - use acid based product Dorado General DIY Discussions 10 02-18-2013 11:42 PM
Proper way to use muratic acid for basement cement block. Trucon01 Building & Construction 17 01-16-2012 05:36 PM
Cleaning brick with muratic acid /window wells bsa_bob General DIY Discussions 9 11-16-2011 02:37 PM
Muratic acid on aluminum clad windows jarrodbowles General DIY Discussions 25 05-01-2009 05:42 PM
