Mortar Tint - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-15-2012, 06:57 PM   #1
Rewards Points: 264
mortar tint
What do you all use to tint mortar?
Any problem with adding a little water based paint?
7echo is offline   Reply With Quote
Old 07-15-2012, 07:27 PM   #2
Rewards Points: 13,300
Why not just buy the morter that matchs what your your trying to do?
Any concrete supply should have some samples of all the differant colors avalible.
Morter is never tinted with paint.
Are you trying to match something you already have?
Old 07-16-2012, 07:14 AM   #3
Rewards Points: 264
Joe wrote- 'Are you trying to match something you already have? '
Yep. I was recommended to use type S. I did a few samples and they are too dark. Need to lighten it up a little so it blends in better.
I will go by the block plant today and see what colors are available.
Old 07-16-2012, 08:25 AM   #4
If it's just a little darker it's because it has not dryed out yet. It will get much lighter once it does.
Old 07-16-2012, 09:33 PM   #5
Rewards Points: 152
Take a sample of what color your trying to achieve to a brick supply company. The have swatches you can compare with. Then buy the closest you can get. DO NOT recommend mixing paint with mortar ever. And if you paint it, be ready to come back next year and paint it again.
TRUEPRO is offline   Reply With Quote
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 11:41 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 08:52 AM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 08:44 AM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 12:13 PM
Plan to install new fiberglass tub; questions about process for mortar underneath lazzlazz Kitchen & Bath Remodeling 1 05-02-2010 05:53 PM
