Mortar For Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-01-2012, 01:28 AM   #1
mortar for stone
I have done a fair bit with dry stack and want to give building a shed a try. I have a good supply of basalt stone of about the right size. When I look online for advice on mortar, the UK sites all say use only lime in the mix, and the US sites say either 1:1:6 or 1:2:9. So, with this conflicting advice, I am kind of stuck. Any ideas would help!
oldguyskier is offline   Reply With Quote
Old 08-01-2012, 11:54 PM   #2
Concrete & Masonry
Rewards Points: 526
Ideally, you'd want to know the approximate compressive strength of the stone you're using, which can often be found by contacting a local veneer stone supplier. Then, you'll want to choose a mortar with a compressive strength slightly lower. For example, most Type S mortars will achieve around 2500 psi in strength, and our the choice for most local stone veneers HERE. A Type S mortar can be simply produced at about a 1:1:6-8.
jomama45 is online now   Reply With Quote
Old 08-04-2012, 09:30 AM   #3
Thanks. I will take a chunk of the stone I am using to a local stone supplier and see what they say. Good advice! I am likely going to get some cut ashlar from them for the corners in any event.
Tags
lime , mortar , stone
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 11:41 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 08:52 AM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 08:44 AM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 12:13 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 09:57 PM
